Question about Scotsman Prodigy Air Cooled Cuber C0330MA 1A
Need to reset unit for start after changing inline filter.
Water pressure has dropped over time. when softener is bypassed, water pressure is fine
A inline water softener functions similar to a filter. When a filter become clogged it restricts water flow. Perhaps this is what is happening with the inline softener unit. Try changing to a new unit.
Dec 21, 2015 | Water Water Heaters
Change the water filter
I believe that this is an automatic warning to get you to replace the inline water filter located in the back of the refrigerator side up near the top. This sells water filters at 30+ dollars a pop. There is a procedure in your manual to replace the filter, but you could just reset the warning by holding the "filter reset button" for 3 seconds. that button is on the front door of the machine.
Jun 13, 2014 | KitchenAid Superba KSRG25FK Side by Side...
Kenmore refrigerator water filter bypass
That is a tough one. You can remove the water hoses from the housing but it won't be easy. Unless the housing itself is broken I don't think I would recommend bypassing it. Now if you really do want to go this route, here's how I would do it.
1) Turn off the supply
2) Carefully remove both lines from housing
3) Using the proper fittings, splice enough line so that you can position the new inline filter at the rear of the unit.
4) Attach the proper quick connect fittings to the new lines.
5) Install the new inline filter .(You may wish to secure the new assembly to the back of the unit)
6) Turn supply back on and check for leaks
As far as which filter, there are many to choose from. I would just get an inexpensive, inline filter made for ice makers. just be sure you get the correct quick connect ends for your new installation.
You can also purchase a complete kit which comes with mounting hardware, a filter and everything you need. This won't be inline though. It will be a separate housing which you will just mount remotely.
Good Luck!
Feb 02, 2014 | Refrigerators
The compressor of unit not turn on again after unpluged
You can just unplug the relay and shake it. If it rattles, it's bad.
What is your model number?
Nov 01, 2012 | Refrigerators
Fuel pump needs to be replaces on 2000 Chevrolet suburban, do I also need a new filter, relay and induction?
Do you know for sure that the fuel pump failed or do you have a bad relay? If the fuel pump relay is good no you don't need to replace it. The fuel pump unit comes with the sending unit and a sock filter. I would replace the inline fuel filter when you replace the pump. In line fuel filters need to be replaced every 36000 miles. If that filter starts to plug up it makes the pump work harder which leads to premature failure.
Jan 17, 2011 | 2000 Chevrolet Suburban
Change the inline fuel filter
relief fuel pressure.remove air intake duct .the dohc engine remove the fresh air hose inlet hose from cam shaft cover.disconnect large under hood fuel line.near intake manifold support bracket on the left side of vehicle. look under vechicle where gas tank is there is a fuel filter with disconnects.
Feb 04, 2009 | 1994 Saturn Sl
Sub-Zero 680 - Service light flashing/need to change the filter
The service flashing means that you had a long run time over a period of time. You can reset it by turning the unit on and off or if you have a door alarm button hold that for 30 seconds and that will clear the fault code. If it comes back you have a problem that needs to be addressed such as cleaining the condensor. There is no factory filter on these units. If there is a filter it is most likely under the unit, which can be accessed by removing the kick. THe kick plate is held in place by two phillips head screws, remove them and have a look. If it was done by a "professional" they should have put an inline shut off valve for easy replacement of the filter.
Nov 20, 2008 | Sub-Zero 680 / S
Scotsman Prodigy Air Cooled Cuber C0330MA 1A Logo
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
