Question about Sony KP-65WS510 65" Rear Projection HDTV-Ready Television
I have sony KP-65WS510 TV, started reporting convergence problem and showing pictures 3 different color. After I talk to Sony Technical Support turn OFF and ON method for initial trouble shooting.Now TV not able to see pictures. Whenever turns it ON no picture and Standby/Timer LED blinks.
  • Sony Master
  • 8,457 Answers
Tv have convergence problems first,fix the convergence board first.The tv have mis R,G,B colors lines alignment have 3D pictures effect.The tv convergence board have totoal dead 2 ICS convergence ICS and some or all it resistors.U know how to do basic's soldering?U have tools like a soldering iron,desoldering pump or solder witch and solders?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy ur tv make and model of convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.Now,the projection lamp, might need to replaced too,after fixing the convergence problems.
Posted on Aug 27, 2010
Convergence does not work. Black spot in corner of picture
Convergence will not cause the black spot--picture will look 3d or colors skewed, confirm model please and a clear idea of what set is doing or not.
Oct 14, 2012 | Sony KP-65WS510 65" Rear Projection...
Possible Lamp Sensor Problem
Google the model number for six blinks for that is an error code---this set uses no lamp---it has 3 picture tubes
Mar 11, 2012 | Sony KP-65WS510 65" Rear Projection...
The left half of the picture has gotten blurry, with pink, green outlining what seems like 3 different pictures of the same thing. The left half works fine and the HD of direct TV is good on that side. I...
The tv have a problems known as a tv convergence pictures problems,it is dead.Tv set have any colors lines like R,G,B mis alingnments,have colors shadows pictures or a 3D pictures look alike?Yes,than the tv set convergence board it is dead to causes all these pictures problems.The tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set covergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 18, 2011 | Sony KP-65WS510 65" Rear Projection...
On my Sony KP-65WS510 The colors are misaligned in the picture and the picture is bowed. Any ideas? Thanks!
This problem appears due to convergence output ICs failure located on D board in tv. There are two big black ICs that need to be replaced, soldering work is required.
Let me know are you handy with electronics stuff repair and can replace parts in circuit board to provide you more technical info OR local tv repairman will do this job for you.
Thanks.
Nov 23, 2010 | Sony KP-65WS510 65" Rear Projection...
IHAVE A COVERGENCE PROBLEM WITH SONY KP-65WS510 THE RED AND BLUE ARE OUT OF SYNC.
Ur tv convergence are dead.U know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 01, 2010 | Sony KP-65WS510 65" Rear Projection...
Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
Apr 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Kp-65ws510 convergence problem
I found throwing it out in the yard and running it over with my skid steer and then driving to Best Buy for a new one fixed the problem.
Mar 11, 2009 | Sony KP-65WS510 65" Rear Projection...
Sony KP-65WS510 Convergence Problem
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Jan 17, 2009 | Sony KP-65WS510 65" Rear Projection...
Convergence problem?
Screen looks 3D
>>>Solution<<<<
Jan 14, 2009 | Sony KP-65WS510 65" Rear Projection...
Blue and red color are off, picture is not clear
convergence amp ic bad
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-65WS510 65" Rear Projection HDTV-Ready Television Logo
152 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
