Question about Hotpoint RB787 Electric Kitchen Range
I have a ge hotpoint range,model#hrmr3800zww-3,the main burner stays on full no matter where the setting is,low to high makes no differance to the temperture
4 Suggested Answers
SOURCE: Left front burner remains on high.
change the left control, it's not controlling the power in the burner
Posted on Jan 25, 2008
  • 116 Answers
SOURCE: Top right burner on hotpoint gas range doesn't light
there is a spark ignition in the middle between the front and back burners....one for the left side and one on the right side. When it was cleaned i bet that the spark ignitor was slightly bent towards the front burner...now the gap is too big to fire the rear burner...the ignitor is very similar as the spark made in those push down lighters. so its safe to play around and adjust them as needed to make them work...Go ahead and take it apart and tinker with adjusting it...until you get both front and rear burners running again the way it was before.( peek at the otherside as a reference and try to make it match)
I hope this helps you out a little bit 8-)
Posted on Jun 06, 2009
marka19
  • 1430 Answers
SOURCE: Right large burner cooks on high no matter what setting.
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at http://appliancehelponline.com/infiniteswitchvideo.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Posted on Jun 08, 2010
GE Spectra burner stays on high
if this is the one with the auto temp burner , defined by a sensor sticking up from its center , this maybe a normal condition for it without a pan on it , as I had one of these come on my new stove , as being a exe chief for 6 years id always set my flame height before setting the pan down , this feature took me some getting used too !!! to say the least !!
but now that im used to it , its great I love it , no more burnt on messes , works great with caramelizing things !!!
Feb 08, 2016 | GE Kitchen Ranges
GE TrueTemp range JBP30W0B1WW — 3 of 4 burners stay on HIGH even when set to low/medium.
as there is no make /model listed only a guess would be the switches
Dec 26, 2015 | Kitchen Ranges
One of the burners when we turn to low goes on very high
The switch for the burner that goes to high no matter what its actually set at is defective and that burner switch needs to be replaced
GENE
Oct 09, 2011 | GE Spectra JBP78 Electric Kitchen Range
Jun 08, 2010 | Hotpoint RB787BHBB Electric Kitchen Range
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
Ge true temp stove top burner wont stay on
dont know how old unit is or how familiar you arewiththe unit, but the burner will need to heat up and cycle off/on. no matter how high or low you set the setting it will heat to a specific temp and cycle off, if hte burner remained RED all the time the glass would crak( so dont go by appearnce of burner, the glass should dictate the temp
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Jan 18, 2008 | Hotpoint RB787 Electric Kitchen Range
Simmer is to hot
I am hesitant about answering your question because if the flame is adjusted incorrectly it could be dangerous.
Remove the knob and look inside the stem of the gas valve. You will see a very small adjustment screw. This is where you adjust the flame for the burner.
What I usually do is light the burner and turn it to the lowest setting. Hold the stem in this position and turn the screw. They are usuall kind of stiff to turn.
You want to adjust the flame so that it just comes to the top of the burner cap at the low setting.
This is the important part!!!
When you have got the flame adjusted, put the knob on and turn the flame to high. Quickly turn it from high to low, if the flame goes out, adjust it higher. Repeat this test until you can turn it from high to low quickly and it stay lit.
Also important to remember. When turning the screw, a little turn goes a long way.
Post back if you have any questions.
Oct 31, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Hotpoint RB787 Electric Kitchen Range Logo
50 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
