Question about D-Link Computers & Internet
My D-LINK wireless router will only connect with a cable. This started happening last week.
  • 220 Answers
Go to start/control panel/network connections and right click on wireless connection then left click repair connection.
Sometimes this will relase and renew the ip address of the wireless machine and allow it to access the internet.
Posted on Aug 27, 2010
My D-link router (dir 615) saying is connected but have no internet access
Wired or wireless? Check all cables, have you tried to connect with a Ethernet cable to the ISP modem, if it connects, try connecting via the cable to the D-link. Work you way through the devices one by one.If it connects via the cable, it's the computer's wireless adapter. Will other computers connect? Or contact your ISP to verify the signal, have a tech come out to analyze the signal. It may be outside. It's happened before, to me.
Dec 26, 2012 | D-Link DIR-615 Wireless Router
Last night my motherboard burnt due to powersurge from the ISP provider switch. they are not believing that the power surge is from the switch, anyway. i have cable internet connection of 10mbps i dont...
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Aug 12, 2011 | D-Link (DI-784) Wireless Router
Router loses connection
It does sound like it, if it still happens wired as well as wireless.
Time for a new 1.
You could try a reset to factory default on the router, as a last chance, you never kknow
Jul 22, 2010 | D-Link DSL-G604T Wireless Router
Can't access internet wireles router says connected hp is a vista
If Nothing else changed in the last 2 weeks, such as a new router, or other hardware changes, AND it just started happening, I suggest you do a "system restore" to a date BEFORE the problem started.
This should correct the problem, and if you did any updates or other software installations, you will need to re install them.
Finally, one option prior to system restoring is to turn off the wireless router (unplug it) and then wait a minute. Plug back in. Then turn on your computer. You can try this first if you haven't already..
Good luck..
Apr 23, 2010 | HP Pavilion dv6000z Notebook
Service provider did an update last week now my DIR-625 router is not picking up any wireless connections any ideas how to fix?
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 28, 2010 | D-Link DIR-625 (790069292637) Wireless...
We keep getting dropped for known reason .
Your internet modem needs to be reset to find the router first. The modem will find the first address when rebooting the entire system or if something gets unplugged..
I've had great success doing the following:
First of all turn off ALL computers, routers, modem ...everything... Then connect power to the main routing source... usually you've got your modem plugged into this.. Just start the router first with all ethernet cabling etc disconnected. Then secondly, connect power to the modem... As the modem connects, it will find the router ip address first... then you are set to turn on the wireless, and the other computers... and the router should designate proper ip addresses for all the peripherals and keep them connected without dropping someone off to allow the other address on... Hope this is clear.... So first the main router, then the modem followed by everything else... Let me know what happens ... and if you need more help...
Mar 15, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
Router
check you cable connections, try to check if you can go online wired to the router if you are connecting wirelessly. You can also bypass the router and connect directly to the modem to make sure its working.
Jun 15, 2008 | Belkin (F5D7230-4) Router (587009)
Unable to detect my router
This is because your router is setting your pc at a different IP address than your original modem. Make sure router is set to enable DHCP which gives out an automatic ip address and check your wireless card and network cards are set to obtain ip address automatically. It may take a few re-starts to get on the internet as your systems will need to clear their previous DNS settings. Also i assume you have set up the home network wizard (XP) as you are now using a router and not a direct modem. Also try Start>Run, then type ipconfig /flushdns then press enter.
Dec 27, 2006 | D-Link AirPlus DI-524 Wireless Router
Cannot connect wirelessly, but can through my network cable
After a few tries and re starts it may connect itself, but if not go to Start>Run, then type 'ipconfig /flushdns'. Try connecting again, but ensure your wireless card is set to obtain IP address automatically and you have enabled wireless connection and DHCP in your routers menu. Hope this helps
Dec 05, 2006 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
