Question about Yard Machines Red Edger
The coil for the choke broke. Where can I get a replacment?
    President:
  • Yard Machines Master
  • 1,545 Answers
You can check for this part and posssibly get it here:
http://www.ereplacementparts.com/
Posted on Aug 27, 2010
I have a 1986 glowing 1200a it cranks up run smooth still it warms up it will idle cold and when it gets warm up to around 2800 rpms the choke cable is broke be the problem if it stuck closed some
Yes indeed the choke being closed even a little will cause this. Replace the choke cable and stop your problem. After warm up the choke should always be fully open.
Jun 11, 2017 | Cars & Trucks
How to replace choke lever
Take it into a garden machine repair shop. They will need to see it and order the part. Ask them how much to fit it. I don't think it will cost much so not worth trying yourself.
Google
make repairs <your city>
May 15, 2016 | Garden
How can I get my choke to open
The tube you're looking at is called a "heat riser". Warm air from off the exhaust manifold will rise in the tube, and warm the carb. If your choke doesn't gradually open with that, then most likely, it's stuck or the temperature coil is broken. Check that the choke can be easily moved with your fingers. .. Lubricate as needed.
Nov 02, 2014 | Cars & Trucks
99 FXDWG, Choke cable broke, bike stalled then wouldn't start. I fixed the choke cable but bike still won't start. Any ideas?
"Crank" and "turn over" mean exactly the same thing. I think you mean it won't "fire". How did your choke cable break on the highway? You shouldn't have been pulling (closing) the choke at that point - does that ride have other issues?
It might be flooded now - try letting it sit for several hours, then try starting with the throttle WIDE OPEN and no choke - that helps clear extra gas out of the cylinders.
You might also need to pull the spark plugs and dry them out thoroughly.
Aug 13, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
I replaced a coil on a stihl weedeater, fs 55 rc, and am having a problem with flooding. also I need the gap spec for the coil/mag
put a piece of paper between coil and magneto magnets, then tighten down. Just so it is not scraping or hitting when you pull it past the magnets . The flooding is because your possibly leaving the choke on to long . Only pull it a couple times, when choke is on. Then turn to half choke.
Sep 01, 2013 | Stihl Garden
Having trouble shutting off Stihl chainsaw
the kill switch wire might have broke between the coil and the switch
May 19, 2012 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
Replacement of choke lever on a 2007 yamaha xt 125cc.
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Replacement choke lever for 2006 xt 125
Choke wont stay up No problem watch this easy fix
Yamaha XT 125R 2005 Service Information
OEM parts for Yamaha
YAMAHA XTZ 125K Owner Manual
Jan 08, 2012 | 2006 Yamaha XT 125 X
Choke lever . Can I fix this myself? broke off and
According to the model, maybe JB Weld the choke lever back together and fuel lines are completely replaceable....get 'um at a lawnmower parts/repair shop. They are Tygon lines.
Jun 05, 2010 | Garden
Engine starts and runs,mows for 30 min then chokes
i had the same problem i talked to a repair shop and they said the coil was going bad and when it heats up there is a short in it (follow the spark plug wire back to the motor and the coil is there ) i replaced the coil pack and problem solved, hope this helps.
May 14, 2010 | Garden
Yard Machines Red Edger Logo
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
