Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Tv turns on picture pops up for a second and then screen goes dark
  • 4,234 Answers
As stated by others here, the problem can be in either the inverter section or the power supply. I have seen this symptom caused by defective driver transistors in the inverter circuitry as well as by poor solder joints in the power supply. The fact that the picture shows up for a while indicates that the voltage required for proper funciton exists. It is just getting interrupted. This can be self inflicted should there be a shorted driver transister because the increased current draw will cause the protection circuit to shutdown the circuit. Please have this checked by a qualified service tech. There are high voltages present that can be dangerous.
FYI - There are no blink codes for Westinghouse sets.
Dan
Posted on Aug 28, 2010
  • 10,594 Answers
It seems back light inverter board stop working for some reason, most probably back light inverter board or power supply board has some problem.
Local tv repair shop will help you to identify what board is bad if you have no experience of tv repair.
Posted on Aug 27, 2010
  • Bud Martin
    Bud Martin Aug 27, 2010
    Look for cold solder joints in the power supply module, it is very common problem in this model.
    It can be the 24vdc power supply problem or the backlight problem as indicated by WELCOMEJEE. http://s807.photobucket.com/albums/yy352... LTV-32W1/
    If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
    Please see my basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lc...
    http://s807.photobucket.com/home/budm/al...
    http://en.wikipedia.org/wiki/Capacitor_p...
  • Westinghouse Master
  • 8,457 Answers
Picture flashes few sec.dies,still have sound?Yes,than the 2 or 1 long board call the LCD inverter boards are dead.These 2 or 1 long LCD inverter boards help the LCD screen to get a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes LCD long inverter boards for the replacement.
  • 3,866 Answers
Be careful accepting a solution that wil not work.
Let me give you some thing to check.
1. Powersupply board
Again Capacitors are not alwys a tv's problem but you want to check anyhow this sounds like the inverters are fireing but loosing power.
Do you have sound?
If you have no sound as well and do not have any SOS codes on the front. check that power supply.
Inverters the fire and then shut off might not be the inverter. A Fault in the power supply can also kill power to that inverter as it is hooked up to the supply. Be careful. Do not work on anything unless you know what your doing. Things can get worse.
  • Shahid Electronics
    Shahid Electronics Aug 28, 2010
    * Do not work on anything unless you know what your doing. Things can get worse.*
    Great advise that applies on everybody, I agree with you.
If you are familiair with electronics, and know how to use a multi meter
you can meassure the resistance of the back-lite inverter trafo's
the value should be between 900 Ohm and 2.2 k resistance
measure between pin 1-8 4-5, (trafo dependant), if the value is lower or higher as noted, then the trafo is defektive, replace if needed.
you can do this with no power connected
note, only do this if you are educated in electronics, or know what your are doing.
i'm sorry fr my poor writing
Posted on May 27, 2014
Turn on the TV, red light stays on, picture goes blank after a second.
I have the same problem. Factory reset did not help (hold Vol-minus on set and menu on remote five seconds, then unplug). Can there be something in service mode that would help?
Aug 04, 2012 | Panasonic Viera TH-50PX80U Plasma TV
Picture shuts off
Is there a dark patch when you see the picture, easiest way to check is on the tv tuner with no cable attached, this way you have a grey static screen, if there is a darkness across the screen when it lights for that breif moment, then it may have a broken backlight tube. Had the same problem with my 32" LG.
Jul 29, 2010 | Astar LTV-32ASB 32 in. LCD Television
DELL 2208WFP LCD-Comes on normally, but almost immediately goes dark You can see something on the screen if you look closely. Turn it off and back on you see it then dark. any help?
I believe the power led button is still on while the screen goes dark, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes dark after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes dark.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
My Sony plasma tv made a pop sound and now picture is dark.
You will need the y and x sustain boards replaced, possibly the buffers. very expensive repair. you can replace one board but its best to do all of them.
Jan 22, 2010 | Sony 50 in. Plasma TV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
Nov 23, 2007 | Sony PlayStation 2 (PS2) Console
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Picture problem
Usually that symptom is caused by cracked solder joints on the vertical output IC. As the IC starts heating up, the picture starts breaking up at the top with several "dancing" dark lines appearing, the top scrunches down and then when the vertical quits altogether, the screen goes completely black. A good slap on the side of the TV might make it happen faster or clear it up temporarily. If you have experience working on PC boards then you can resolder the pins of the vertical output IC but if you have never soldered parts on PC boards then allow a qualified tech to handle it for you.
Nov 20, 2006 | Sony KV-35S42 35" TV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
776 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
