Trying to figure out which part I need. After turning on, screen comes on for a split second then goes back off. Power still appears to be on as Vizio logo on bottom of TV stays lit
    Problem Solver:
  • 24 Answers
Cleanning,,,,trun wire of screen split insider,,,,,,try the vizio,,,,wire look like the word....
Posted on Aug 27, 2010
Peavey DPC1400x turns on, plays sound for a split second, buzzes, then goes silent. All lights show green though. What could this be?
This sounds like a power supply capacitor leaking causing a dc bias problem and amp protection shuts it down.
May 06, 2014 | Peavey Audio Players & Recorders
Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Jul 22, 2010 | Acer AL1917W LCD Monitor
Monitor comes on for a split second , and then off
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Screen is black with power light on. When I turn the power off and then on the screen comes up for a split second then goes black again.
Look for caps with bulging top in the power supply section first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 08, 2010 | Proview PL913B 19" Flat Panel LCD Monitor
931B tries to come on but shuts back off
Problem solved by changing 3 capacitors (C112, C113, C316).
Replace the 470uF 25V with a good quality low ESR type and the two 820uF 25V with 1000uF 25V low ESR types.
The 1000uF caps should be 10x20 in size, however I managed to get 13x20 caps in, but it was a bit tight.
Apr 03, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Tv will not turn on
Get a power extension cord to connect your TV power to another (zone)room by using a different outlet and see if that is still does it.
Remember when you unplug the TV,you want to give it 15-20 seconds first .
If it still have the same issue,i hope you have the warranty,you are going to need it for repair.
solutiondoct
Nov 11, 2008 | Hisense Televison & Video
A17w221 goes off automatically with power on
I have the same problem. The next stage is that the picture won't come on at all and the blue light will constantly blink. I think the light source is bad. Noit sure though.
Mar 25, 2008 | Envision A17W221 Television
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
