Question about GE JE1540 Microwave Oven
What are the dimensions of the GE JE1540WV002 microwave oven?
ghost4548
  • 776 Answers
SOURCE: GE COMBINATION MICROWAVE CONVECTION OVEN JVM1790BK CONVECTION OVEN DOES NOT GET HOT
change the tube/heating element
Posted on May 26, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Bulb replacment for GE Microwave Model JE1540wv002
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel. It has wiring, schematics, and troubleshooting info.
Yours will be found as JE1540WV02 (instead of 002) here: http://www.tinyurl.com/gv383
Posted on Nov 28, 2007
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: I have the same problem
GE Customer Service is here and they should be able to tell you what the "drop-in replacement" is for your model.
Of course, most microwave problems are pretty simple to repair.
If you're interested in our advice there, please reply back with your detailed symptoms.
Otherwise...
Posted on Jun 08, 2009
  • 87 Answers
SOURCE: GE Microwave Oven Installation
If the top of it butts aginst your cabinets you will have to take the bolts from the inside of your cabinets around the front area that that are holding it up out (use 2 people) once they are out it "should" still hang there, next step slowly lift it an inch or so (then you will be no longer on the back suppot) again use 2 people, then you can pull straight out. hope this is what you are looking for.
Posted on Oct 03, 2009
What are the dimenisons for the GE microwave JVM163WB004?
Jaquetta, best that I can find from GE's website is the following
Width: 29 7/8"
Depth: 15 1/16"
Height: 16 15/32"
Hope this helps!
Jul 18, 2014 | GE Microwave Ovens
Je1540wv002
follow this steps and fix it use the VOM 4f0e2859-427b-40e9-9e89-e7e7bb5bc8da.gif. God bless you
1. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Jun 11, 2013 | GE JE1460 Microwave Oven
I need the dimensions of the GE Spacemaker XL Model JVM1653WH01
For dimensions look at the GE Appliance web site at: http://www.geappliances.com/ then search for JVM1653WH01
This will take you to the product information page for the JVM1653WH 1.6 Cubic Foot Over the Range Microwave Oven with weights and dimensions, installation instructions etc.
Oct 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Do you know the dimensions of the GE jvm230 over-the-range microwave oven?
Just measured mine as I'm looking to replace it.
30 inches Wide
15 inches high (front)
16.5 inches high (rear)
13.5 inches deep
Nov 18, 2010 | GE JE1540 Microwave Oven
Is there a replacement microwave for a GE JE1540, 16.75 deep, 12 3/16 hi, 23 5/8 wide?
Called GE Customer Service (thanks MicrowaveSvc), as they were very helpful. The replacement microwave (GE) is: JEB1860DMWW with new trim kit: JX2030DMWW. This are P/N for white, I am sure they have something for other than white. Total job took me about 5 hours (self install, moderate ability), where the final 1 to 1.5 hours was working on the final trim kit install. Couple of notes. This oven is about 6 to 8 inches deeper. The kit wanted about 1.5 inches more horizontal space than my original install, but I made it work. I had to shimmy the vertical space by 1 inch. Good Luck!!!
Jan 10, 2010 | GE JE1540 Microwave Oven
Otherwise...
Jun 07, 2009 | GE JE1540 Microwave Oven
New Microwave
Well one would presume you could simply measure the bracket and the microwave, and ask a retailer for the dimensions of units with similar dimensions.
They may also have this bracket and be able to compare the sizes before purchasing your new one.
Not knowing the dimensions of either the bracket itself or the microwave, this would be the only solution i can think of.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Nov 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
513 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
