Question about Kitchen Ranges
I have a 56C frame GE motor single phase, 3450 rpm 115/230 volt 5KC37JG 783. There is no plate showing how to convert to either voltage nor to change rotation???Terminals are L which is connected via a metal jumper to terminal 4 with a metal jumper to terminal 5. There is a metal jumper from terminal 2 to 3. The other post is also labeled L. It runs slowly and I think it is connected for 230 volt. I need 115 volt. Rotation is now CCW viewed from the terminal end. I need the opposite. Can you help?
micromaster
  • 3614 Answers
SOURCE: WIRE CONNECTIONS
may i know the exact model # of your unit, and the part # of your switch control.
let me know, thanks.
micro
Posted on Aug 27, 2008
Controlfrk
  • 304 Answers
SOURCE: replacing ge radiant range oven heat unit
Typically, wires of the same color are connected together. Marking terminals before removal next time will prevent problems.
Posted on Aug 19, 2009
heatman101
  • 43501 Answers
SOURCE: Oven only heats to 150 f regardless what the
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 16, 2010
jmgldsmth
  • 1889 Answers
SOURCE: Need power input wiring diagram for 230V use
you can get the manual here:
http://www.millerwelds.com/service/locate_om.php
Posted on Jul 24, 2010
  • 86 Answers
SOURCE: viking broiler will not light. New ignitor, and
Yes you're right the gas valve failed.
Good luck, Dickson
Posted on Nov 04, 2010
Testimonial: "Wow! A confirmation of my diagnosis in very short order! Now the painful part: chasing down the part. Thank you so much, Glen M."
How to reverse rotation of single phase, 1/2 HP, 110V electric motor.
Changing the "polarity" of the start winding by swapping the wires over should reverse the direction. Lots of online motor-related generic and manufacturer information is available.
Feb 16, 2015 | Air Tools & Compressors
How do I change the voltage from 115 volts to 230 volts on a duel voltage motor?
When you open motor you will find schematics on inside of housing.Sometimes its just a switch you push from one side to another.
Sep 12, 2014 | Baldor VL3515 Single Phase C-Face Motor,...
Wiring schematic for MTB217 cooper b line
I would suggest taking a closer look at the motor name plate. I am not familiar with a 120/240 three phase service. When I checked the web it shows: Voltage 115/230 (that is single phase), Max Amps 115 Volts = 19.2 Max Amps 230 Volts = 9.6 , Single Speed, Square Flange, RPM = 3450, Threaded Shaft, Frame = 48Y Used on the following models: Sta-Rite Max-E-Glas, Max-E-Glas II, Dura-Glas, Dura-Glas II, Dyna-Glas, Dyna-Max Pentair Whisperflow, Pinnacle and Anthony AR2 Series. You should also show what voltage you are connected to.
Mar 14, 2014 | A.O. Smith SQ1102 Pool Pump Motor
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
Single phase motor 220 convert to110v; do you have switch wire inside the motor
There should be a label showing the change, one wire gets switched over to a different screw, all motors are different, but all basically the same, some will not switch. It would be just as easy to run a new line to your motor and it will be right, single circuit, 220 volt,?amp, no worries., Your motor as is will not run in 110 volt mode at all. Hope this helps.
Feb 26, 2012 | Delta Table Saw Tool Base 50279 Band Saw...
I have a 3 phase electrical motor for my air compressor, How would i connect this from the air compressor pressure switch and towards the electrical source 120V? (for low volt)
If the electrical 120 volt source is single phase, the only way to run this motor is with a single phase to three phase converter. Best to sell the three phase motor and obtain a similar horsepower 120 volt single-phase capacitor-start motor (1750 RPM) for the compressor. You would also require a 3-phase pressure switch for use with the 3-phase motor. Hope this helps!
Nov 05, 2010 | Garden
I want to reverse rotation on my A.O. Smith 120/230 volt single phase 1.5 HP motor. Catalog number B762
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
Oct 07, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I have a motor running 3450 rpm 230 volt 9.6 amp what is my horsepower?
Ok, but I need to know a few things;
Single phase motor or 3 phase motor?
What is the % efficiency?
Feb 17, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
I want to re wire an electric motor for low volt
Look on the name plate. If it says under 'volts' 120/240 that means it's dual voltage and you can use either voltage to run.
Sep 25, 2009 | Electric 1hp 1800RPM 56C Frame 12 Volts Dc...
I wish to rewire a single phase electric motor with compositor's that is currently setup for 230 VAC to 115 VAC. The motor is a Ingersoll-Rand Air Compressor motor with the following nomenclacher. Single...
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Aug 26, 2009 | Air Tools & Compressors
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
