Question about Roland MA-10D Main / Stereo Speaker
I need to find out how to mount stereo MA-10D speakers to a wall. I can't see any mounting capabilities on the back, sides, top, or bottom of the speakers. Has anyone successfully mounted speakers like these before?
  • steveshimek Aug 27, 2010
    These speakers were given to me by a friend and they don't have any of the original packaging or templates. Are you suggesting just cutting shelves into the wall? I'm not sure I understand completely.
    Thanks!
    Problem Solver:
  • 11 Answers
Hmmm. .U don't have option given for speakers to fix them onto the wall. You have to do the following steps.
Things U need are:
  • Masking Tape
  • Level
  • Pencil
  • Keyhole saw
  • UL Class 2 speaker wire
  • Fish tape
  1. Locate the studs closest to where you'd like to install your speaker. You'll want to install the speakers in between the studs.
  2. Tape the template that comes with the speakers in the center. Check to make sure your configuration is level and plumb. Your template will tell you exactly what size hole to drill to insert the speakers. Trace the opening you need to cut into the wall or ceiling
  3. Cut the hole using a keyhole saw or a drywall saw. Keep the section you cut open in case you can't install the speaker and need to patch the hole you just made. If the hole reveals plumbing, you need to relocate the speaker
  4. Run the speaker wire through the wall, or fish speaker wire from an existing installation.
  5. Install the brackets to support your speaker if one is included with your speakers. Some speakers use clips to secure them to the inside of the wall.
  6. Strip the protective coating from the end of the speaker wire, and insert it into the speaker jacks. Test your speakers now if the wires are attached to an audio source. If not, locate the other end of the speaker wire and hook it up. Testing now will save trouble if you run into problems.
  7. Surround the speaker with insulation to enhance the sound. Secure the speaker into place, and do any necessary patching or painting
Posted on Aug 27, 2010
How to hang a mirror without nails
Instructions
    • 1
      Select a location to hang your mirror by holding it up on different areas of the wall. If possible, ask another person to hold the mirror while you stand on the other side of the room to judge the best spot for displaying it. Once you've decided on a spot, mark the wall lightly with a pencil along the top and bottom edges and/or corners of the mirror.
    • 2
      Place a level against the wall horizontally at the top pencil marks and tilt it up and down slightly until the bubble centers inside the glass tube in the level.
    • 3
      Draw a line lightly with your pencil along the edge of the level.
    • 4
      Lay a thick towel or blanket on a flat work surface and place the mirror on top of it, reflective side down.
    • 5
      Wipe the back of the mirror with a damp cloth to remove any dirt or debris sticking to the surface and wait 15 to 20 minutes for it to dry. In addition, wipe the wall down and wipe or air-dry it. If either surface has greasy or oily stains or other marks, wash the surfaces with mild detergent, rinse thoroughly with a damp cloth to remove any residue, then wipe or air-dry.
    • 6
      Affix strips of heavy-duty, double-sided, mirror-mounting tape to the back of the mirror along the sides, top and bottom.
    • 7
      Remove the paper backing from the double-sided tape strips, align the top of your mirror with the pencil line on the wall and press the mirror firmly against the wall.
    • 8
      Erase any visible pencil marks.
Tips & Warnings
  • If you need to mount a heavy mirror without putting a hole in a wall, hire a professional mirror installer.
  • Never touch the adhesive surface with your fingers because you can transfer oil to the adhesive that can reduce its ability to bond to surfaces.
Related SearchesReferences
Mar 29, 2013 | YouTube Videos
03 dodge stratus and my new speakers wont fit in
You will need to modify the mounting by making support plates from MDF. You don't tell us how much larger (deeper) the new speaker magnets are, compared to the puny ones on the Factory speakers. Most Car Stereo shops are capable and are accustomed to such mods.
Amclaussen.
Mar 16, 2013 | 2003 Dodge Stratus
I have a pair of Mission M50's and am considering mounting them on the wall. However, it says something in the manual that they shouldn't be too close to the wall and there is no obvious way of...
The reason they shouldn't be too close to the wall is because the refelction that would generate, making them respond unpredictable, mostly in the lower frequency response, Booming basses are most likely. That won't danmage your speakers, so if you don't mind, you can always attach them to a wall with after-merket mounts. You'll have to screw those in the back of your speaker though...
May 23, 2011 | Mission M50 Main / Stereo Speaker
Is there a specific wall mount for this TV to swival in all directions
Acquiring wall mounts for television are according to preferences. For example, wall mounts that provide the TV dynamic directions to suit operators requirements would have separe requirements. The multidirectional wall mount provides the TV capability to swirl around several angles. Howeever, acquiring wall mounts as requirement to encamp the TV also placement on safe areas from which the device is observable is an alternative considerations. TV wall mounts provide multi purpose functionalities. For example, TV wall mounts that provide both encampment housing placement hinging to an area, and finallly capable of multidirectional functionalities available for acquisition at retails. Also possible are acquisition of customisable wall mounts to suit the type of placement area required on TV sets either suitable at various locations. For example, TV wall mounts are customsiable to house sets that require functionalities with complimentary devices like decoders, modems, DVD players, VCR recorders, or cable wiring. The process of acquiirng wall mounts is achieving interhrety of the TV set, housing available devices requiredm and achievifn viewer egonormics. Consult room device area estimate expert before acquirng wall mount to ascertain the appropiate conditions capable of providing egonomic experiences. Goodluck
Jan 08, 2011 | Televison & Video
I have an ULPT-X Omni Mount that I will be using with a Samsung 65" LED. How do I mount the ULPT-X to make sure that the exact center of the TV will be in the center of the wall space it will be hung on. ...
What do you mean by centered on the top and bottom? It doesn't need to be centered in the exact part of the wall for the tv. it all depends on what your viewing height is for where you want the tv vertically. Once you figure that out you mount it where you want it for your personal viewing preference.
Thank you,
Lee
Oct 26, 2010 | Televison & Video
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
How to replace rear shocks on 96 bmw 328i
Inside the car carefully pry up the speaker covers off the rear parcel shelf and undo the two screws that secure the speaker assembly onto the shelf. Release the clip and carefully from inside the boot pull the speakers away and disconnect the speaker connections
Open the boot and remove the carpet from the rear "wall" by unscrewing the 4 retaining "nuts" at first by hand and then using a phillips screwdriver.
Lift this out and lift out the floor carpet. Carefully pull the side carpets away from the boot interior. They are held in 3 places : on one of the retaining bolts by the rear carpet, by a metal ledge at the top near the rear lights and by the ledges on the plastic parts in the boot.
Jack up the car and chock the front wheels so it can't roll anywhere. Also put something underneath the wheels so they cannot drop down when you undo the shock mounts.
Using a 13mm socket undo the two top shock mounts ONLY once you have supported the wheels so that you dont put stress on the suspension arms. Pry off the rubber dust cover.
Undo the lower shock retaining bolt and carefully lift the entire shock away from the car.
The old knackered shock and shock mount!
You need to recover the lower cup, upper cup and bump-stop from the old shock. To do this you need to remove the top mount from the old shock. If you look at the top of the piston it has a flat section to it. Get a set of mole grips and clamp them onto the flat section, do this as tight as you can so that you dont round it and using and adjustable spanner undo the piston retaining nut whilst holding the piston shaft using the molegrips.
You need to recover 3 pieces from the piston shaft. 1- the bump stop, 2 - lower cup, 3 upper cup. Using the new shock mount as a template cut out a gasket from cardboard (the box the mount came in is ideal) to go between the upper shock mount and the suspension tower. Incidently according to the haynes manual this is made of rubber but mine was made of card! under no circumstances put the upper shock mount directly into the suspension tower.
Put the 3 pieces onto the new shock and tighten the piston nut to secure the shock mount and put your new gasket onto the upper mount.
Use the opportunity to clean the suspension turret - do the top and the underneath making sure it's all clean and dry.
Put the new complete assembled shock into the suspension tower and either get someone to do up the top bolts a few turns or rest the bottom of the shock in the inner circumference of the wheel and lift it into position by lifting it up using the piston nut and then do the bolts up a few turns.
Bolt the bottom shock bolts back into place after putting some nut-lock on the threads and tighten them up securely, then tighten up the top mount securing bolts and put on the rubber dust cap.
Put the side carpets back in making sure the speaker cables aren't trapped behind, putting in the end nearest the tail lights first making sure it's behind the retaining ledge both at the top and the end. Then do the centre section and finally over the bolt at the rear of the boot. Put the rear carpet back in and do up the retaining nuts. Reconnect the speakers and engage the lip and push the speaker up until the clip clips into place and do up the securing screws and clip the speaker cover back on.
About What's New BMW In-Depth How To Pages My Projects Garage Sale Galleries Communities Links Contact Donate
Jul 07, 2009 | 1999 BMW 328 Series
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Wall Mount
I found that the screw holes in the back that should have thread from the top down are threaded only near the bottom of the hole. You will need to purchase longer bolts/screws to attach the mount. Also, if it has the built in DVD player you will need to purchase a few plastic washers to build the mount up over the DVD player and to make the other side even. It is POSSIBLE to mount this TV it is just a large amount of work! I hope this can help!
Jan 10, 2008 | Televison & Video
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Roland MA-10D Main / Stereo Speaker Logo
66 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Vito Vacirca Jr.
Greg Cann
Greg Cann
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
