Question about Vacuums
Electolux renaissance no power when I plug into outlet
  • AerusGuy
    AerusGuy Mar 11, 2018
    Fyi, Electrolux Corporation, the manufacturer of the Renaissance cleaner (Models C104A & C104H), changed its name to Aerus LLC in 2000 when it sold back the Electrolux trademark and brand to its original parent company, AB Electrolux of Sweden.
    Go to aerushome.com to locate an Aerus dealer for assistance, sales, parts, literature, and service.
    Best.
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=576614
Generic problem for all Vacuums
Electrolux renaissance
Posted by maryannn2l on May 06, 2008
No power when I plug into outlet
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You may have 3 problems that I can see. You may have a bad electrical outlet, but I doubt it, the bad cordwinder cord or a short in the cordwinder itself, or a connection came loose in the motor section. If you need further assistance then contact your local vacuum cleaner dealer in your area or contact the Electrolux factory listed below. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 27, 2008
I have a renaissance cansiter vacuum. When I plug in the canis ter no hose attached, it does not come on like it shouldn't , however when I attached the hose and wand I turn it on it will start to ru
It is running properly if you are doing what you say you are.
It should NOT run without the hose and should with it plugged in if the electronics in the hose and vac are working properly. This was the major problem with the Renaissance Model and was only manufactured for a few years.
With 30 yrs. experience dealing almost exclusively with the original Electrolux, I have a legitimate store front business and do service by mail at a reasonable cost if interested. mickeymackmark1@yahoo.com
Hope that helps! Mick
Dec 07, 2014 | Electrolux Vacuums
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
Electrolux Vacuum Renaissance Power head brush won't turn
if it is making a humming sound but not turning you belt is broken, if it is not check the reset switch (little res button) if that doesnt work check the connections between the cord of the powerhead and the wand, the wand and the hose, and the hose and the vacuum
give the hose itself a good look over sometimes the wires up by the grip break in the casing
Mar 12, 2014 | Electrolux Vacuums
Electolux hoover 1600w power plus wont start
John, first off, you have a Hoover upright vac, not an Electrolux. If it won't start, check cord to be sure it's plugged in properly to a live socket, then find and push reset button, frequently found near the corner on the rear of the base. (Small red circle). If that fails,. then you need to take it to the nearest repair shop for diagnosis.
Nov 02, 2013 | Hoover Platinum Collection Upright Vacuum
Vacuume cleaner modle #N03052M When i plug it in
What type of unit is it...Epic, Renaissance, Guardian,etc?
Oct 09, 2013 | Electrolux Vacuums
How do you replace the 'after filter' in the electrolux guardian?
1. Press latch and open the door that covers the tools.
2. Squeeze clips at front of tool tray, lift and remove.
3. Remove filter.
4 Replace filter.
5. Replace tool tray and close door..
Instructions can be found in the Renaissance manual, which you can download from the following site. Go to "older models", find Renaissance and click on it, then click "download". Instructions are on page 9. The Renaissance is basically the same model as the Guardian.
http://www.aerusvacuums.com/support/manuals/
Nov 28, 2010 | Electrolux Guardian Bagged Canister Vacuum
I have an electolux [ lux classic] vacuum cleaner, and there is no power to it. I think it is a loose wire, as it was tempermental before. I can't find a way to get into it to see if it is a wire
Does the green power light located on the top of the vac come on with the cord plugged in the outlet ? If so your switch could be bad. If not, you could have a bad connection or a broken wire. Caution ! If you do get into the vac, you can cause more damage to the vac. Is the vac more than five years old. If not, your vac is still under waranty and you should get it fixed for free. Take it back to you Aerus/Electrolux shop. You can find out if the unit is still under waranty by calling the customer service with the serial number. They can tell you. 1-800-243-9078.
If you still want to get into the vac (which I do not recommend) let me know and I will tell you.
Joe
Nov 15, 2009 | Electrolux Vacuums
I have an older electolux vacuum. It says Epic
Vacuum either has a clog or full bag that is overheating the vacuum causing the thermal switch to shut it down.
Hope this helps.
Aug 14, 2009 | Electrolux Vacuums
Vacuums Logo
334 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
