Question about Frigidaire FEF336BC Electric Kitchen Range
Have an FEF336BC Electric Range, the oven will not heat to correct temp. I hear oven "click" like it closes a relay. Any ideas to where to begin with the trouble shooting?
    President:
  • 1,430 Answers
The problem is usually the element has failed. The clicking is the relay, that is a good sign the main board is probally good. First check to see if the element gets warm at all if it does replace the element if not, you will need to see if it is getting power. Here are a couple links that should help
http://appliancehelponline.com/ovenelementvideo.html
http://appliancehelponline.com/rovenwillnotheat.html
Posted on Aug 27, 2010
Oven won't work
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Aug 14, 2011 | Frigidaire FEF336BC Electric Kitchen Range
My kitchen range oven is not working. every things looks fine , timer is on ,tiking sound coming but element is not heating up what went wrong
heatman101
Sep 18, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Why does my fridgeaire stove lock only when i preheat bake?
It locks so that you can't open the door untill oven is at temp. Some people open and close, open and close the door and the oven never gets to reach set temp. After it is at temp, the oven can "catch up" faster, returning to set temp.
Apr 07, 2010 | Frigidaire FEF336BC Electric Kitchen Range
New oven thermostat acting nuts
can't find our model with this model # .. i would try cking the wiring / making shure it's correct . normal orp when heating the light is on . not heating light is off . although the thermo is new it may be bad / or possible that it not the correct replacement . hope this helped **** ..
Dec 09, 2009 | General Electric JBS07M Range
Oven does not heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 25, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Jenn-aire s176 electric oven will not hold set temperature
Sounds like you have a bade temp sensor.Have a great Thanksgiving.
Nov 25, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Frigidaire gles389ebd oven doesnt heat
How long does it take to reach the temperature of 225?
Thanks, Bill www.applianceoutletservice.com     to chat live with me Thanks
Oct 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven won't heat up to set temperature
IF THIS IS A GAS RANGE, AND IS USED ALOT, 4YEARS IS ABOUT THE LIFE EXPECTANCY OF THE IGNITOR FOR THE OVEN. IF THE IGNITOR IS WEAK, IT MAY NOT OPEN THE SAFETY VALVE. WITH A FLAT IGNITOR, IT REQUIRES 3.3AMPS TO OPEN THE VALVE. IF IT IS A ROUND IGNITOR, IT REQUIRES 2.8 AMPS TO OPEN THE OVEN IGNITOR.
IF THIS IS AN ELECTRIC OVEN WITH AN ELECTRONIC CONTROL, I WOULD SUSPECT THE OVEN SENSOR AS THE DEFECTIVE PART. AT ROOM TEMP, IT SHOULD READ ABOUT 1084 OHMS OF RESISTANCE.
IF IT IS A MECHANICAL CONTROL(WITH A KNOB) IT MAY BE ADJUSTABLE BY REMOVING THE KNOB AND INSERTING A THIN SCREWDRIVER UP THE SHAFT OF THE CONTROL AND TURNING A SCREW IN THE SHAFT TO CALIBRATE THE TEMP.
Apr 04, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire ES340 clicking noise and display blinking when oven door opens
sounds like a bad door/light switch.it cant seem to tell if door is open -closed and clicking really fast betweeen the 2. replace the switch
Mar 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
23 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
