Question about Ecoquest Breeze AT Living Air Purifier
Unit will not do anything - Ecoquest Breeze AT Living Air Purifier
    President:
  • 670 Answers
If there is no power, check the fuse and make sure that the filter clip is making contact with the safety switch.
Posted on Aug 27, 2010
Cannot get the 'SERVICE REQUIRED" light to turn off even after cleaning the plate with ammonia and water.
Just remove the filter from the back of the unit. You will find an Ozone sensor above the fuse. Carefully remove
it and put the unit on MANUAL mode and the service light will go out. It was put there to help comply government'
requirements and really service no purpose. It did not properly monitor anything so just operate you unit in the
MANUAL mode like the original Classics and it will be fine. Remember to throughly clean the unit once a year.
Oct 24, 2010 | Alpine Air XL-15 Air Purifier
Ionic Breeze GP unit does work.
Could be a problem with the power cable or a fuse issue. Or it could be a burnt wire, or motor problem. It is difficult to say without actually taking it apart. Best get it serviced.
Jun 02, 2008 | Sharper Image Ionic Breeze GP (SI730) Air...
Repair info for oreck md# a260 unit ran fine and worked well until I heard popping noise from front of unit probably bad connection of high voltage to filter cartrage fan stopped working if i turn unit on...
It depends on what you paid for it.I checked out Oreck and they had no free downloads available for anything.Here is their customer service though to find out about parts,diagrams,etc.Some places will not sell parts to consumers,some will.Here is the link.
http://www.oreck.com/SiteMap
Jul 27, 2010 | Oreck (AIRCOM1WOI) Air Purifier
Recently cleaned unit. now i am getting arcing on
The arcing sound comes from a loose fit. You may have to bend the contact bar so it fits tightly against the unit.
Feb 28, 2010 | Ecoquest Breeze AT Living Air Purifier
Can someone tell me how the two wires in the bottom of the unit are supposed to be attached? I have not opened the unit, but see that one end of the two wires are attached to the two little plastic...
The wires you see are the high voltage grid wires -- these burn thru and break -- the more often the unit is cleaned the longer these wires last, but 18 months max is my experience.
There is no easy way to fix this -- even if one does the complicated, extremely nerve wracking reapir (with titanium wire) the unit will fail again soon.
Far as I know, there is no longer a repair service for these units.
Charlie
Sep 28, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Have cleaned unit and will not work. The clean
I just fixed my proffessotional ionic. Im not sure what I did. lol. I took the screws out of the bottom, didnt see anything wrong, tho there is a piece of plastic in there, I dont know what it is. I cleaned the 2 center long metal like things, cleaned the contacts that the metal blades touch. cleaned the wires with alcohol and qtips, put it all back together, and it came on!!!!!!
Apr 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Flair sparking
Contact healthytech@triad.rr.com. They will be glad to help you.
Apr 09, 2009 | Ecoquest Flair Air Purifier
Shortness of breath, coughing when working out near unit.
I think you've answered your own question: "symptoms cease when unit is turned off".
I don't want to be alarmist, and I certainly do not suggest that there is anything unsafe about the Breeze AT.  Nevertheless, this machine generates ozone, which is an upper respiratory tract irritant.  It is absolutely vital that you follow the manufacturer's instructions to the letter when operating it. Personally, I would never want to be in the same room as a working ozone generator (and I know of at least one ozone generator where the instructions specifically tell you to keep out while it's working).
Your machine may be on a setting where it is producing more ozone than is desirable. If you no longer have the manual, you can download a copy at www.ecoquest.com (click on the DOWNLOADS tab, then on OTHER on the green bar. The Breeze AT is in the Owner's Manuals list.).
If in doubt, play safe!
Mar 05, 2009 | Ecoquest Breeze AT Living Air Purifier
GP Professional Series Ionic Breeze - Simply Quit Working
Sharper Image models are no longer supported because they have been recalled since they were proven to be ineffective.
Here is a link about the Chapter 11
Here is a link for the EPA about ionizers
Jul 06, 2008 | Sharper Image Professional Plus Ionic...
Can the unit be mounted in a window?
there is no reason why not if the outside part is properly weatherproofed and screened to stop insect etc ingress - easier may be to duct the unit to a hole in a window - use at least 125mm/5inch ducting and dont make it too long. It is not recommended to run the unit in this way, however, as you will almost certainly find that the filters etc will block very quickly due to many more airborne particles(especially living ones) in outside air (depending on your situation) and the fact that inside a room with the unit running you have a relatively closed system that will steadily get cleaner as you use the unit. best way to test this would be to run the unit normally but outside for a while to see if it functions ok. Hope this helps - i cant see that you would gain anything from running the unit in a window apart from higher filter replacement costs :)
Oct 09, 2006 | 3M OAC100 Air Purifier
Ecoquest Breeze AT Living Air Purifier Logo
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
