Question about Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo
DVD will not read. All types. recorded and pre-recorded.
    Problem Solver:
  • 24 Answers
Clean,,,,,,inside......check it out,,,,,sometime u have to open it,,,to clean it,,,to work,,,
Posted on Aug 27, 2010
Why does not the philips dvdr3480 record?
I would start with the dvd format used for recording, the simplest being dvd+r and dvd-r. Does the unit play a pre-recorded dvd and/or cd? If not, the laser assembly would be the first suspect. The delay in reading discs can be a sign of a borderline laser. Is your record overwrite function turned on, this overwrites previous material when starting each new recording when using +-rw discs. Verify if a format is required for the type of disc used for recording, page 45. Is the correct country/region selected?
Oct 26, 2017 | Televison & Video
Will not read DVDs
When I place a blank or ore-recorded DVD into mt Panasonic DMR-EZ47VEB it indicates NO READ. Can I solve this problem?
Feb 20, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
My panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Jun 25, 2009 | Panasonic DMRES15 DVD Recorder
Unit will play pre-recorded dvd's but when trying to record on any blank dvd disc it say's read then preparing and then invaid disc ?
Older DVD players (as well as some lower end products) will not play computer recorded disks. Another option may be which DVD are you recording on. DVD+R or DVD-R. Some players will only play one version. (usually -R I believe). Or could be a problem with youtr authoring program. Try a different program and/or type of DVD Recordable disk.
Aug 13, 2008 | Televison & Video
LG service centre in mumbai
I have an LG DVD Recorder Model DR 389. It first stopped recording (was getting message "regional code incorrect" & was playing DVDs. Now when a recorded or pre-recorded DVD is put in - it just keeps saying "Reading" .... and doesn't play.
Could it be the lens ?
Jul 29, 2008 | Televison & Video
Lg 766 wont play a pre recorded dvd every thing else is fine
Not all DVD players will play a pre-recorded DVD that was made on a computer. These types are designed to play only what is called pressed DVD's.
When a CD or a DVD is recorded on a computer it is not really the same as when the media has been press recorded.
Most all of the new model DVD and CD players will play computer recorded media. When buying a player, it is important to make sure that the specs are what you need.
Jerry G.
Jul 11, 2008 | Televison & Video
Dvd not recording
One touch function won't work from pre recorded VHS tape. Go to
www.RCA.com under this dvd model and read the first line.
Secondly you will have a better luck to use sony dvd+r .
Good luck
Nov 22, 2007 | RCA DRC8335
Not reading pre-recorded dvd's and ocassionally not re-wrtten dvds
Over recent months my recorder has stopped reading pre-recorded disc's and more requently re-writer disc's. I had thought that the region had some how been altered, but not too sure now. Is there a way of checking? Or is there a problem with the laser block. I have stripped the machine down and thoroughly cleaned (but no dust found) and no loose parts. I have reset to manufacture default but this hasn't helped.
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 1 Other User Has The Same Problem Comment by Guest, posted on Dec 19, 2007 DVDR70-051 recorder functions generally becoming more and more erratic. DVD-RW discs I have recorded sometimes say 'disc error' sometimes 'no disc' sometimes start ok but cycles round and round for 5 - 10 mins before stopping, sometimes goes straight into play at last position, won't stop back in menu just goes straight to stndby. Factory reset dosn't help. Wont play pre-recorded discs without going into menu and messing around. It seems to damage or not record RW discs properly a lot of the time. Not even sure if it's resetting to factory settings properly.
Oct 28, 2007 | Philips DVDR70 DVD Recorder
Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
