Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
The wand will not stand up on its own when attached to the vacuum head. I had earlier models which did not have the adjustable height and this was not a problem--I simply turned the wand to the side. But I cannot do it on with this wand. Any solutions?
  • 10,865 Answers
Hello. There is a small part on that wand which enables it to stand up on it's own. It sounds like yours is worn or broken. Take it to your local vacuum repair store and they will have you back up and standing in no time. The part is about ten dollars. J.
Posted on Aug 27, 2010
Can it be fixed ?
What's the make and model number of your vacuum?
May 20, 2013 | Vacuums
S36 vacuum head dosent come on
There is a fuse inside the machine but if that were bad the entire unit would not come on. Check the reset in the back of the power head next to the height adjustment. If not, Check the voltage coming out of the hose if you are getting 120V+/- then the hose is fine(be sure when checking the voltage you have the power brush switch on) You can also check the continuity/voltage of the wand. The voltage should also read 120V +/-. If the reset didnt fix it then you more than likely have a bad hose or wand.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Jan 10, 2013 | Simplicity Vacuums
My telescopic wand height adjustment won't lock the height in place. The wand extends to full height with no locking in place. How do I fix it?
These wands have a very small nub that locks them into place. They wear out very easily. You might have to replace the wand.
Nov 28, 2009 | Euro-Pro NV31 Infinity Vacuum
Nedd power head wand for Fantom Model BPSRLC51
the best bet would be to look on ebay. the fantom line was discontinued
Jul 28, 2009 | Fantom Vacums Lighting Canister Vacuum
I have the dc 17 animal model and there are no instructions in how to use the attachments,how they connect and so on.I have to assume that this is not an uncommon question considering that the box was...
You can call the Dyson helpline for information on how to fit the attachments. Generally, you can fit them on the wand and the hose (wand - directly on top of the red piece of plastic, hose - take the wand off the back of the vac and press the red button where the hose connects to the wand - this will remove the wand and you can attach the tools to the hose). With a DC17 Animal you probably have a Mini Turbine Head (a tool with its own brushbar - greay with red bristles) - if you have a gray button on it this is probably making you ask how it attaches to your vac - this tool is actually compatible with many other Dyson models but in your case it just fits on top of the hose and/or wand - it doesn't click into anything. As long as the fit is tight/snug, you're good.
Jul 14, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a Kenmore progressive cannister vacuum cleaner.
There should be a pile height pedal on rear of the attachment, just behind the where the wand goes into it, near the handle release pedal. Just keep clicking on it to go through the height settings.
Please rate if this helps :)
Mar 05, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Carpet power head will not stay attached to telescoping wand
to answer your last statement, if you do not have a receipt, the warranty will go by the date ofyour serial number. the first 4 digits are the month and year. this model usually has a 1 year wty. the wand button may not be protruding as far due to dirt under the metal band. however you may still have an issue with the neck on the powerhead which will require shop service.
Jan 18, 2009 | Hoover S3765-040 WindTunnel Bagless...
Carpet attachment
Check the plug ends at the top of the wand and the plug going into the hose handle, also at the bottom of the wand. It sounds like they may be burnt, if so they will need to be replaced. One cause of these connections going bad is not turning the power head off when connecting or disconnecting. Therre are other causes, the switch in the handle is going bad, also some of these cannisters have a relay mounted by the vac motor, sometimes they go bad.
Mar 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Miele Vacuum cannister
Most times you have to replace the neck on the powerhead. Sometimes the switch in the handle of the hose will have a bad solder connection. But S300 is not a good model number, also the powerhead has its own number on the bottom, so couldn't look up parts for you.
Feb 21, 2008 | Miele S300 Bagged Canister Vacuum
Power brush problem
Check the contacts where the power head attaches to the wands and also where the wnd attaches to the hose. If any of the contacts look burnt, then they will need to be replaced. Unhooking them when power is on is what causes most of these problems. But if they look ok, could be a problem inside the power head, or in the circuit board that is inside the cannister.
Feb 11, 2008 | Samsung Ultra Quiet 9073R Bagged Canister...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
