Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Phillips Magnavox I was watching a DVD,, then put it on pause..then came back and the green light on the tv is flashing, and now when I even try to watch the tv.. there is not picture..just a colored haze...
  • nanci goodman Aug 24, 2008
    my tv just went off and the light is flashing with no picture or sound
    27 in about 4 years old
  • cokeguy0721 Sep 07, 2008
    my screen seems to be fluctuating from its full size to about 2/3 it regular size and back to normal size. this only happens when it is on for about 45 min
I dropped my TV while moving and it fell hard. Now, it will not turn on. When I manually press the on, the light blinks green but no picture. Is it time to buy a new TV?
Posted on Aug 16, 2008
  • 137 Answers
Sounds like your Convertion bord pops. Tv Technical Prop, Take for service.
Posted on Jun 29, 2008
Power green light Blinking, Will not power up.
Got this from Phillips:
Question My TV has no picture.
Answer Press the menu button on the remote. If the menu appears you are probably experiencing a signal or connection problem.
If you have a menu check the following:
  • Video inputs may be shared. If you have sound but no picture, check that audio and video inputs are going to same.
  • Check antenna connections at the bottom of the TV to see if they are properly connected to the TV.
  • Possible broadcast station trouble. Try another channel.
  • Adjust the contrast and brightness settings. Try another auto picture setting.
  • Check the Closed Captions control. Some TEXT modes could block the screen.
  • Check if you selected the correct AV source. (For LCD TV with built-in DVD player, the correct DVD source is AV1.)
If you have been watching the set and you loose picture:
Your TV has a protective mode in case there is too much heat build-up. Check the clearance around the vents of the device to be certain there are no blocking walls or cabinets which would limit the air flow.
Is it installed in a TV cabinet? These models produce a lot more heat than you think. So the last suggestion is a likely culprit.
One other possibility. Some models have these, some don't but look for a small "red reset button" recessed some where in the back of the set near the power cord. It is a built in circuit breaker.
Nov 26, 2007 | Televison & Video
My magnavox 37MF321D/37 will not turn on. It
I had the same problem with the blinking green light. These are the parts one the power supply I replace to repair it. note: If the power supply is repaired you will get a solid green light and the backlight will light up almost immediately.
Aug 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a phillips matchline plasma the power light keeps flashing green then starts flashing red is there a problem with the connection between the tv and the master box?? plz help!
According to " Consumer Affairs. com", the problems with seris of Phillips plasmas are innumberable. And they all start with the flashing red light, from 3 - 7 times. Baased on the information you gave, there is something wrong with the TV itself, not your perifrials. I would contact Phillips/ Magnavox to see if they will pay for an authorized sevice center visit, or even ship you a part to solve the problem.
Apr 11, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Magnavox 32mf231d - Just a blinking green light, No Power
I had this problem, but saw other places that it was a cheesy capacitor on the power supply circuit board causing this. I opened it up and took the power supply board out and it was obvious which capacitor was bad...top was bulging and had black stuff on it. It was rated 2200 uF @ 25V...got a new one @ Radio Shack that was 2200 uF @ 35v. Soldered it in (I stink @ soldering, but gave it a shot and it was EZ). Watching the first weekend of college football w/o waiting on a flashing green light for up to an hour so the TV would start! I'm going to try to find the other websites that directed me to this to say THANK YOU...BTW my brother used to have fits with several Magnovox TV's and thier power supplies back in the old tube style TV days. I thought I didn't need to worry about this with an HD flatscreen, but was wrong. I will think twice before buying a Phillips/Magnavox/Funai/whatever else they are again. They have a long list of complaints and I believe a class action lawsuit to refer to about this problem. They should have stepped up and done something!
Mar 19, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
No picture
if it is dropped you most likely would have a cracked ciruit board. you would need a qualified tv repairman to check tv
Jan 14, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Dvd freezes
If less than a year old, this TV is likely under warranty but should have been taken back immediately to address the issue. I suggest contacting the vendor or manufacturer.
Jan 04, 2018 | Philips Magnavox 27MS343S 27" TV
60" Projection Screen Phillips Magnavox won't turn on
Check the site www.TvRepairKits.com - they put together a kit to fix this problem.
Nov 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
T.V won't turn back on
Sounds like a component shorted out for sure. I will guess he will say, "It needs a new power board". I would guess a transistor or microchip burnt out. Probably ESD damage from a new factory worker.
Nov 14, 2008 | Televison & Video
Unable to record/dvd recorder problems mwr20v6 phillips
I also have same problem and have had no luck with anything I have tried
Aug 11, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
135 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
