Question about Sony VAIO VGN-TZ170N/N Notebook
Broken HDD, HDD to replace. Guide to open the machine to replace HDD
    Sergeant:
  • 223 Answers
Look on the bottom for a couple icons that look like a 50 gallon barrel. this is the hard drive access door. its typically 3-4 screws to open the door. you will see the hard drive its 3.5" wide by approx 4" long. with connectors on only one end. lift the drive out and gently pull the connectors off . presto hard drive in hand. i welcome your comments.
Posted on Aug 27, 2010
  • Trevor Groves
    Trevor Groves Aug 27, 2010
    please note. power off, and take battery out before opening any laptop covers
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Did find the hard drive cover?
    Does my response answer your question? do you need further clarification or help?
Ricoh aficio 3228c error sc 873
Thats a hard drive error. Initialize SP5-832-008 or replace the HDD! Most machines use a simple IDE HDD. Just open the machine at the back, youll see the HDD
Jul 18, 2014 | Ricoh Aficio Office Equipment & Supplies
Top loading LG eco saver washing machine top cover sensor missed. How i can rectify?
Those type of washing machines needs expert services. My advice is, go to your nearest dealer for that particular service. Or, if you want it to fix by yourself, then you must locate the sensor. Most of cover sensors can be found at the end of the cover's guide. You must open the top part of the machine then you can see (probably) a black rectangular attached to the end of the guide.
Most of the common fault includes broken link from the guide to the sensor and a faulty sensor which needs replacement because its a disposable type.
Jun 09, 2011 | LG WFT1071TP Top Load Washer
My hitachi Ls 1000 emea 1 tb is broken. The usb port has comepletely detached and gone inside the actual hardrive. How do i fix it? Can i buy a new usb thing? Can i open the harddrive?
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Thumbs up please if it's any use to you Thank you.
Aug 27, 2010 | Hitachi Computers & Internet
At start up a blue screen appears followed by clicking noises
Sounds like a broken hard drive. Try an OS reinstall first. If it errors out, you HDD may be broken. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
May 14, 2010 | Apple MacBook Mac Notebook
HDD connection has broken
The connector to the HDD is loose on these models. Open the HDD port and remove and then clean the cable before putting it back. I'm afraid it's a recurring problem on this model.
Dec 27, 2009 | Samsung X05 Notebook
I have ricoh 1035 & eror sc990. without hdd ,i can print and copy one side and by hdd i have error. i do . & # toghter for 10 second for soft reset and nothing happend. in code menu: 5801 - 2109 -...
If you use Katun OPC drum in your machine and is work more 80000 copies you need to replace the OPC drum and the drum cleaning blade.After replace the drum perform the process comtrol and the SC990 disipaire.Whenever use other genuine parts and not original Ricoh parts appair SC codes to refer HDD parts.100% this method is working.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Recorder LG - RH361SE (HDD failed) Can I replace HDD?
The hard disks inside the recorder should be exchangable. If you still have warranty, bring the machine to your point of purchase, or repair shop, as directed by the shop you got it from.
As you are at it, consider asking to change to a bigger size HD, and pay a little for the prize difference?
If out of warranty, try changing the disk. These machines should be easy to open, as long as you do not have the electrical cord plugged in and do not touch capacitors that might hold remaining charge.
However, although the disks are mostly standard IDE disks, there might be a software specific to this brand of recorder on the old hard disk, so pls find out if there is downloadable boot images existing that you could transfer.
You might even have a corrupted boot image... and not a broken disk.
Here is a discussion thread with pros and cons about changing the disk:
http://forum.doom9.org/archive/index.php/t-128974.html
Jun 24, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Changing Paper Size
If the blue guide in the back of the tray (called the length plate adjuster) is broken or dislodged, the machine may not recognize what size paper is installed. When the guide is moved, three arms on the right side of the paper tray change configuration. Those arms push against sensors in the machine to tell the printer what size paper is in the tray. You can temporarily resolve this by taping the guide in the A4 position, however you should consider replacing the tray or replacing the guide soon to avoid tape getting into the printer.
Hope this helps!
Mar 20, 2008 | HP LaserJet 4050 Printer
HD Crashed need instructions on how to get into Laptop
You can Visit the following URL http://esupport.sony.com/perl/model-documents.pl?mdl=PCGZ1VAP It has the User manual & the Quick Start guide, using which you can get help on how to replace the HDD on your machine.
Apr 01, 2007 | Sony VAIO Z1VAP1 (PCGZ1VAP1) PC Notebook
Sony VAIO VGN-TZ170N/N Notebook Logo
166 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
