Question about NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router
It was working fine and suddenly I cannot connect with any laptop using the wireless card. The computers see the network and the signal is strong. They just will not connect.
  • wallv Aug 27, 2010
    No, that did not help
    Yes, changing the channel worked, thank you
    Sergeant:
  • 223 Answers
Very common, just power cycle the router, they lock up from time to time. give it about a minute to cool down before you plug it back in, then all should return normal. I look forward to your response. Thanks
Posted on Aug 27, 2010
  • 8 more comments
  • Trevor Groves
    Trevor Groves Aug 27, 2010
    Fair enough, at this point i recommend you connect with a wire, and surf into the routers admin panel, check through the wireless setup, change the encryption key to use some thing new like WPA or WPA2 with a new password. If it was never locked down, someone may have gotten in there and changed your wireless connect key on you. then try again.
    Best of Luck !
  • Trevor Groves
    also change your wireless transmit channel, just in case its conflicting with another device in the neighborhood.
    Yes, thanks, changed the 11G Channel from auto to a number
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    if this solved you connect issue please try to adjust your thumbs up rating, i also welcome any testimonials (they help). Glad to have helped Take care
  • Trevor Groves
    Trevor Groves Aug 29, 2010
    Glad to hear this worked for you
Wireless card not working ze4933
f you suddenly have a problem with your network connection, before you make any changes, you must determine whether you have a problem with (1) the wireless device on the computer, (2) the connection between the computer and the network , or (3) the connection from the ISP provider to the network. Each of these devices / connections must be operating independently before they can all work together.
  1. View the wireless icons in the system tray to determine the status of the devices and connections. Then, open the appropriate utilities for detailed information on potential problems. The detailed windows are: the Windows Wireless Network Connection, the HP Wireless Assistant, and the Device Manager.
  2. When you have the detailed information, identify the specific type of connection problem by reading the connection description statements below. Then select the statement that most closely describes your problem for a detailed explanation of the corrective actions.Internal wireless networking adapters or PCMCIA cards may have problems connecting to a wireless network if the Advanced options are not set properly. For instance, some PCMCIA devices can adjust the power output to increase the strength of the wireless signal.note.pngNOTE:If the computer and router are in the same physical area, you may want to reduce the signal strength to save battery. However, if they are not located near to each other, you can turn the power up to 100% to maximize the signal.Most HP internal wireless cards can be set to turn off to save battery power. If the wireless connection was working but suddenly stopped when using the battery, the card may be turning itself off exactly as planned. You can use the Device Manager to specify the power settings and keep the wireless card turned on.To verify and change the wireless device settings in the Device Manager, do the following actions.
    1. Click Start , Control Panel , System , Hardware , and then Device Manager .
    2. Click the plus sign (+) next to Network Adapters . If multiple devices are listed, you should check the devices one at a time.
    3. Right-click on the network adapter, and select Properties .Select the Power Management tab, if available, and verify the power settings. Not all wireless device drivers have a Power Management option.
    When you have set the Power Management options, close the Device Manager, restart the computer, and attempt to reconnect to the wireless network.
Sep 21, 2011 | HEWLETT-PACKARD Pavilion ZE4933 Laptop...
Laptop not connecting to wireless network
Don't wait tell you laptop is defective, at least buy a new wireless lan before its too late.
Sep 30, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
Connects to network, strong signal, will not connect to internet.
it looks like wireless card in the laptops need to be changed.
Jun 03, 2009 | Acer Aspire 5610-4648 Notebook
Limited or no Wireless connection
It appears that the TCP/IP got disabled or removed.
Check the TCP/IP settinge of the wireless adapter, it should be the same as the network adapter.
Feb 09, 2009 | IBM ThinkPad T41 Notebook
Computer will not connect to wireless router
the antenna wire sounds pinched it is in the usually in the lid and can be found by looking in the hinge area
Look to see if it is kinked
LB
Sep 21, 2008 | ASUS Eee PC 900 16G Notebook
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Check the wireless network card
try to reinstall the driver
Jul 27, 2008 | Computers & Internet
Wireless not working
Check for the wireless security settings in your modem.. and check if your airport is connected properly, if it is connected properly, then you would get a valid ipaddress, try resetting the modem and reconfigure your wired and wireless settings, if possible , try to upgrade the latest firmware for your modem and then reconfig it..
Jan 21, 2008 | 2wire (1000-000057-000) Modem
may be the connection seting is changed what you have to do is ope my network place then by the left side click view all connection then you will see your wireless connection icon righe click on it then click property then chang the seting as you want it my name is Abreham Tigabu from ethiopia
Jun 25, 2007 | Sony VAIO PCG-K35 Notebook
Wireless connection keeps falling
It may be just a problem of the signal bouncing around and your laptop is struggling at times to find the signal. Some earlier laptops don't have a wireless booster built in the screen. Go to your laptops' web site and see if there are any updated drivers for your wireless card. If still unhappy with results purchase a USB wireless dongle and dissable wireless card, it may have a better reception area, or purchase a signal booster that works in conjunction with your wireless router.
Dec 18, 2006 | Edimax BR-6114Wg Router (BR6114WG)
NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router Logo
37 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
