Question about Pantech Duo Smartphone
Won't power up
When i press the on button the orange light comes on steady for 15 or so seconds then goes off and... nothing.
  • 3 Answers
Charge it for a while before trying to turn it on. if its completely dead it wont power up immediately
Posted on May 07, 2008
No power only orange power light
Hi, It most likely is a faulty power supply or a motherboard issue. Remove the power cord then press and hold the power button for at least 30 seconds. Then plug it back in and hit the power button. This will release any static buildup that might be in the computer and sometimes that causes it not to boot. If nothing is happening it is more likely your power supply than the motherboard.
Mar 19, 2012 | Dell Inspiron 530s Desktop Computer...
Why my printers show alarm U051
Hi, khaircarrier
That error has something to do with the page counter and the ink system. You'll need to reset your printer to clear the ink counters, after resetting it'll not display the error code again. Follow this procedure to reset the printer:
  1. Power off the printer.
  2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
  3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
  4. Release power button (the screen should now say 'Service Mode').
  5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
  6. Press the power button once, (the orange light should go off).
  7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
  8. Press the power button, and wait until printer has shut down.
  9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
The page counter should now be reset. That should solve your issue.
Mar 07, 2011 | Canon Office Equipment & Supplies
My HP 6720 won't switch on. When connected to the power source, a steady blue light comes on (normal) then goes to a light blue then goes blank. If I press the 'on' button, a flashing orange light appears...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 19, 2010 | HP Computers & Internet
I'm tying to copy, comes up with check ink u163 col
It seems as though the ink counters are not being reset. Please follow the instructions below to reset your printer. Please read and follow the directions carefully as skipping any steps will not correctly reset your printer.
10. The page counter is now reset.
Re-install the printer cartridges and give it a try.
Aug 15, 2010 | Canon PIXMA MX310 All-In-One Printer
THe pc gives a steady orange light when power
Sounds like its in either standby or hibernate. Try unplugging it if it wont power on, press the power button, wait for 2 minutes then plugging it back in then turn it on. Afterwards, go into power managment, and find where it asks what do when you press your power button change from hibernate/standby to ask what to do.
Mar 07, 2010 | Dell OptiPlex GX520 PC Desktop
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
One page jammed after switching off when 1 page printed. Orange light on
Hi ,
First off all u switched off the printer and on switch off mode press the green button and on pressing the button switch on the printer hold that button for 5 seconds and then release the button whenever u realese the button the printer start migrating . After migrating if the printer have same problem then u reinstall the printer driver and again reinstall the driver, after reinstalling the driver the printer will working fine .
May 26, 2009 | HP LaserJet 1010 Printer
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power
LEDs light alternately, Alarm in orange and Power
in
green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Pantech Duo Smartphone Logo
74 people viewed this question
Top Pantech Computers & Internet Experts
Jax Planet
Jax Planet
Trisha
Trisha
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
