Question about Kenmore 72062 Gas Dryer
I have a Kenmore Elite Gas Dryer model # 110.72066100. When I turn it on the motor runs for about 1 minute then shuts off with an E2 error.
  • chalapathi12 Aug 27, 2010
    Dryer vent is clear.What is burner turn off?
    Top Expert:
  • Kenmore Master
  • 76,649 Answers
Does the burner turn off as well? is the dryer vent clear, if u have not checked do so, clogged/obstructed? dryer vents cause an overheat and quickly trip the thermal limiter
Posted on Aug 27, 2010
  • 3 more comments
  • yadayada
    yadayada Aug 27, 2010
    the gas burner that heats the air
    Yes, Gas burner turn off.
  • yadayada
    If your air flow is good, then the problem is your thermistor, I have changed many of these before due to this problem.
    Here is a new thermistor you can order:
    The thermistor is just to the right of your thermal fuse on the blower housing.
    Look at this parts diagram:
    http://www3.sears.com/imaging/ImageP...&...
    #42 is your thermistor, #59 is your thermal fuse
    the link you send it's not openings. Where i can get the part, I live in Novi,Mi.
  • yadayada
    yes the link is not working right now, web site must be down, but u have the written discription. below is a link to a good source for the part
    http://www.repairclinic.com/Appliance-Pa...
Hi I have a kenmore elite oasis dryer. And all of a sudden it only will run for about a minute and then it shuts off. I tried turning it back on again and it does the same thing. Then after the third time...
The first suggestion I have for you is to simply run an Air Fluff cycle with no heat.
If the Air Fluff cycle runs okay then the problem is most likely with the thermistor.
You can try to run the dryer with the vent hose off and see if there is a difference.
Oct 07, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
I have a Kenmore Elite HE3 gas dryer that is not heating. When starting a cycle, it will run for a couple of minutes, then stop with "E2" on the display. Lint has been cleaned out from entire...
Ok
E2 means the control board has sensed problem or shorted thermister. Located on blower housing.
Replacing thermister should solve the problem. This picture should help.DISCONNECT POWER BEFORE ATTEMPTING
Elite Dryer schematic
Was thi helpful?
Aug 22, 2011 | Dryers
Kenmore Elite Electric Dryer - in recent days the dryer will not start but makes a buzzing noise. If the dryer starts it may tumble for 2-3 to three minutes and then shut down. When the unit shuts down...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 18, 2011 | Kenmore 74892 Gas Dryer
I have a kenmore elite gas dryer model 11070952990 that won't start at all.
heatman101
Apr 20, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
I have a Kenmore Elite gas dryer - model # 110 70052990. Just hooked it up after a year of not using it and it continues to shut itself off on Normal dry (begins at 40 minutes) and shuts off at 38 minutes....
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Dryer 63942 Push on button, turn the timer to 30 minutes.Within 10 minutes the dryer shuts off.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 11, 2010 | Kenmore 63942 Dryer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Kenmore 72062 Gas Dryer Logo
95 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
