Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
I have a ML88T model. It is 1 year old and worked just fine. all of a sudden no lights are working. power is OK to the transformer but the switch doesn't seem to work. what can I do?
I wrote power pack troubleshoot checklist:
http://www.fixya.com/support/r8391011-power_pack_not_working
Posted on Feb 27, 2011
I replaced a lighted switch which was not working and was not lighted. The new switch does not work and is not lighted.
From what you are stating I am going to make a few assumptions. That the new switch has been connected properly and that the lamp you are supplying works OK in a different outlet. The only thing left to do is to make sure that you have voltage on the switch. Once this has been ascertained, if no voltage, then you have a broken connection or wire on one of your other switches or outlets as the power is simply 'jumped' (in parallel) around the house from switch to switch or outlet to outlet. If the switch has power, make sure that it is indeed going through the switch when activated. If it is, then the break is between the switch and the outlet. A cheap non contact 'voltage stick', which is a tester which has audible and visual indication when it comes near voltage is a good tool to have if not adept with electrics. Please be careful. Cheers Bob
Dec 14, 2016 | Electrical Supplies
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
TV was working fine and then the picture has totally gone, just a Black screen as though it is switched off, Audio on all channels are fine and turns over as normal. No Text no nothing on the screen...
solution
step 1 : at first test your fly back transformer
step 2 : A.C. transformer test
step 3: adjust TV yoke coil
Send report :babul_jpi90@yahoo.com
Jul 28, 2011 | LG 50PS60 50 in. Plasma HDTV
Can you help me troubleshoot a Intermatic Landscape Transformer - 88 watt - ML88T?
The following link carries ML series power pack troubleshooting, plus links to trippers and manuals, plus information about 5 year warranty.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment with followup question if needed.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Intermatic 24hr Outdoor Timer
Hi ... I have three Malibu timers ,one is ML 88T the others are ML44 T The first one I connected did not work ML44T , I check the stopers,The light bulbs the cord the outlet ,nothing. I did worked. I...
You did not say if these power packs are new or if they stopped working.
The humming sound says transformer is working, but terminals have to test 12Volts DC.
If power packs are older and were left plugged in when bulbs were not working, then power packs can go bad.
There are no replacement parts for power packs except trippers.
Open following page for power pack troubleshoot plus links and information:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 22, 2011 | Malibu ML88TL 88Watt Low Voltage Power...
Malibu Model: ML200TW Transformer Automatic timer not working
You can buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
Jul 23, 2010 | Intermatic Malibu 300W Power Pack...
No picture on Samsung LCD 40" TV
Nobody could guess that! it depends on where you are in the world. For Instance I am in australia network.
Call outs generally run to $AUD90 and $90 and hour Min 1 hour.
You do not say whethyer the power light lights up so its again guesswork.
If the power light IS lit then there is power from the wall to the primary coil of the power transformer. I would then suspect either the secondary transformer has failed, or that a fuse after the secondary and pre picture/sound module has blown. The power supply ( cant by bits) costs around $200. The fuse 0.60
add to the callout fees and you get some idea of the cost can cost half the value if a $1000 TV The plasma screen hasnt gone so that's always a plus and its rare for the video board and sound module to fail simultaneously. So my bet is the poer supply side and fuse
Aug 13, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Rangehood lights not working
I have a Fabyka Range Hood and know three other people who have had this exact problem (i.e both lights go out simulatneously but fan works fine). In my case I was able to pin it down to the transformer used by the halogen lights. This is an electronic transformer so it is less tolerant of power surges and such.
In the case of Fabyka the transformer is a black box connected to the inside of the hood with sticky tape with a black and white wire and two red wires. It is only used for the lights.
It is connected to the AC power via a black and white wire. you can disconnect this and us an LED power tester (about $2-$5 at most hardware stores) and see if you have power when you hit the switch.
In my case it is a 70W 120v to 12v halogen transformer. You can by a replacement off Amazon for about $12 including shipping or you can by a new one from Fabyka for about $30. I would suggest getting a slightly higher wattage transformer (I bought a 105watt for a dollar more).
You will need to disconnect the power before replacing but it is an easy fix.
1. Disconnect the AC power connector (black and white wires.)
2. The red wires coming out are the 12volt lines. If there is a connector, you can disconnect this, if not, you may need to cut these off.
3. Pull the tranformer off the back of the inside of the hood.
4. Cut the connectors off the old transformer. (Unless you buy Fabyka's.)
5. Connect them to the new transformer using wire connectors or crimps. (Make sure you connect black to black, white to white, and red to red.)
6. Make sure you have no exposed wires.
7. Connect to the corresponding connectors inside the hood. Connect the AC connector last.
8. Verify that the lights work properly.
9. Use sticky tape (or Gorilla tape) to attach the connector to the inside of the hood.
10. Enjoy the light.
Jul 17, 2009 | Kitchen Ranges
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
629 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
