Question about Smith Corona Office Equipment & Supplies
I have a old Coronet Electric 12 that works beautifully except that the ribbon stays loose and after a few letters pops out of the holding bracket where the key hits.
    President:
  • 2,047 Answers
Various factors could cause such a situation. First check if the ribbon in use is exactly the right size for your device.
If this is a perfect fit then have someone examine the holding bracket for you it might need replacement.
Although you could try to fix the ribbon again and while at it put some folded up paper with it in the holding bracket to give the bracket better grip. But this is a temporary fix.
Hope this solution has been helpful?
Posted on Aug 27, 2010
What is tyyping capacity of SMC 17657 ribbon cartridge
The 17657 ribbon is the side loading "pork chop" ribbon is a fabric ribbon and it shoulden't run out just get lighter until you change it you may just have a bad ribbon.
DickyO
Apr 13, 2010 | Smith Corona Office Equipment & Supplies
One of my large burner not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Sep 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Need serial number for my electric coronet integra wall oven
ther should be 4 screws holding the wall oven in you need to take them out and puul the oven out just alittle and look on the sides,be carefull not to far out
Sep 01, 2009 | Ovens
Front big burner not working
Jul 10, 2009 | GE Profile JSP47 Electric Single Oven
Smith Corona Classic 12 ribbon won't stay in place
Okay...i had the same problem when I replaced the original ribbon that came with my Classic 12. I think it was the ribbon that came with the typewriter.
Anyway, on the ribbon carrier, there are two sets of metal prongs on top of one another. If you get the ribbon behind both of them, it will pop up and not go back down or won't come up at all.
You have to get the ribbon between the two sets of prongs. There's isn't much room and you have to kind of pull the bottom of the ribbon taught and slide it down from the top.
It isn't easy the first time, but after you get it, you won't forget.
As for your ribbon not feeding...take the spools out and make sure the pegs that go into the holes in the spools are rotating when you type. This is what moves the spools. Then make sure you're getting the pegs in the hols when you put the spools back in.
Also, make sure the ribbon isn't twisted anywhere and that it's threaded correctly. Both spools should look identical with the ribbon coming out of the top toward the carrier.
To ensure you have the correct ribbon, got to the Office Depot online store and do a search for Smith Corona Classic 12 and you will get a pretty generic, double-black ribbon that fits and works perfectly...and is so soaked in ink you can reuse each side three times. I don't recall the brand name, but the box is grey with red lettering.
Apr 16, 2009 | Smith Corona Office Equipment & Supplies
Incomplete letters when typing
Ribbon not lifting high enough maybe because it is loose. check ribbon itself if you wind it up does it stay tight, if not bad ribbon.
Jun 17, 2008 | Brother GX-6750 Typewriter
Electric oven range not working
common replace eoc clock get eoc and overlay the black or white cover for the clock is the overlay if you peel the old one off carefully you can restick it on the new eoc pull the range out and remove the 1/4 inch screws from around the top panel after un plugging the range remove the top panal face the front of the range right under the clock remove the two 1/4 in screws go to the back of the range and pull the eoc bracket backwards from the bottom and out take the four screws out that hold the eoc to the bracket turn the eoc sideways and out of the bracket and let it hang screwthe new eoc to the bracket with the two srew holes at the bottom put the overlay on the new eoc and put the top of the bracket in first then push the bottom in making sure the holes in the bottom line up with the holes on the cotrol panael go to the front and replace the two screws then go to the back and with a small screwdriver gently pry the wires off the old eoc and place them on the new one if you get lost theres letters on the wires that match the ones on the eoc replace the back panel plug it in reset the eoc clock all done make shure you get the complete mod# when you order the eoc its on a plate on the left side of the range body when you open the bottom drawer all done
Dec 22, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
108 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
