Question about Dishwashers
The door counter weight seems to have dropped off. there was a loud crash, and now the door feels really heavy, and won't close properly. any ideas??
  • 172 Answers
Hi alisonf,
It sounds like you may have had a spring either come loose or break. You can take the kick plate off the bottom usually with a 1/4 socket or nutdriver and maybe a phillips. Take the screw out of each side and you will see on the far left and right a spring that attaches to the door hinge. One of them will be broken or off. Simply look at the one that is still in place and attach the other back the same way. If broken you can usually buy springs for dishwashers for around $8.00. Good luck and I really hope this helps. Mike
Posted on May 07, 2008
When I close the door on my e36 325i convertable the window won't go up, it normaly drops on opening of the door and goes up on closing but non of this is happening help really appreciated thanks
You have a problem in the window regulator assembly.
Go to a nearest garage and have check the window regulator, sounds like the gear mechanism have been nicked and releasing the window in heavy vibration.
Hope that helps!
Sep 14, 2011 | 2001 BMW 325
Why does the Westinghouse 708 makes a loud noise when spinning
hi, When it spins there is too much weight on one side. You have to open the door and move the cloths around then close the door before time runs out. Hope that helps. Also don't put heavy items in like running shoes (large shoes).
Jul 30, 2011 | Westinghouse Washing Machines
Cannot open the door of the dishwasher.
  • The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
  • If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
  • Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
May 04, 2010 | Maytag 24" Tall Tub Built-In Dishwasher -...
How do i adjust rotisserie counter-weight?
Once I have the meat on the spit rod and in the forks, I will lay it on the brackets on the grill and turn it by hand. You can feel when the heavy side of the spit rod rolls down. Put the counter weight on the opposite side (up side) and adjust the weight up or down until it turns evenly.
Dec 26, 2009 | BBQ Guys BBQ400C/G42 Grill
Taking to long to dry
  1. Separate heavy weight items from light weight items when creating loads. Heavy fabrics take longer to dry because they tend to retain more moisture. To help reduce and maintain more consistent drying times for large and heavy fabrics, separate these items into smaller loads of a consistent size.
  2. Use the appropriate control settings for the type of load you are drying.
  3. Please confirm that the lint filter is clean prior to each new load of laundry.
  4. Divide your larger load into a number of smaller loads.
  5. If you are only drying a handful of items, add a few extra pieces to help ensure proper tumbling action.
  6. Confirm that the exhaust venting ductwork is properly configured. Confirm that the venting is free of obstructions. Confirm that the outside wall dampers are moving freely, that the dampers are not pushed in, and that nothing has been set against the dampers.
Oct 27, 2009 | Maytag Dryers
The door is very heavy when you open it. When you go to open the door it just drops straight down
Sounds like the retaining bracket has come loose on the side its is attached on the inside this is separate to the hinges at the bottom that hold the door on, does the bracket feel loose?
If so you may need a service its is difficult to get in to reattach unless you have done it before dont without at least one other person to help
Oct 15, 2009 | Dishwashers
Door won't close wont lock closed
Check the following if you have problem with your doors:
1)The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
2)Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
3)The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
4)If your dishwasher is new or if you have just replaced a door seal the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 03, 2009 | Westinghouse Dishwashers
My Whirlpool duet washer is making very loud noises on the spin cycle - it still drains and spins but the spin is uneven and sounds like there is something grinding inside. The spin does not seem to be as...
VERY loud noises might indicate a loose counter weight. Open the cabinet then raise the top and check the condition of the counterweights and that they are fastened down properly. The front lower counterweight is held on at the ends by two lugs connected by a formed rebar rod and a spaced bolt in the middle of it. Check these first. Loose you can fix. If the rebar breaks, the counterweight will beat the inside of the machine up pretty good, usually damaging the water pump strainer housing. If this doesn't solve your problem, look at some of the other posts here for other ideas. They're really good.
Regards, --WoobieDog--
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Craftsman Liftmaster
Check your door springs. One of them is most likely broken and is what caused your drive gear to strip in the beginning.
Jun 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Shutters closing while running
The shutters should be gravity closed, which means they are counter weighted just enough to close with no air flow...  when the fan starts, it will create a slight pressure differential across the shutters - when that pressure overcomes the counter weight, the shutters should open...  I assume you open windows and/or doors when the fan runs...
I would check for the following items: a) (unlikely) check to see if the counter weight is adjustable, if so, it may be slipping and needs reset.. I think this is unlikely as I think most shutters do not have adjustable counter weights -- check last)
b) check your attic vents to the outside -- the air being blown into the attic must escape to the outside world, otherwise it will build up pressure and the airflow will drop or stop altogether -- this sounds like what is occurring, at slow speeds, there is insufficient airflow to open the dampers, at high speeds, they open long enough for the pressure to build up and then they close as the air flow diminishes
c)  have you replaced windows, caulked up windows, made any modifications to reduce the flow of air into the living areas -- air must enter the house just as air must leave the attic (assumes you don't open windows or doors)
d)  if you have a fireplace, check to make sure some animal or other hasn't plugged up the chimney -- if the house is tight, the attic fan will pull air from the chimney unless it is blocked
hope this helps...
Jul 25, 2008 | Ventamatic Direct Drive Whole House Fan...
Dishwashers Logo
430 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
