Monitor goes blank
When i turn on my monitor it works for half a second, and then goes blank.
I wondered if i could reset it in some way, but cannot find any reset instructions in the manual.
Any suggestions ?
  • andrewsmith May 07, 2008
    for info - my monitor is an Iiyama ProLite H511S
    will find somebody with a solder and give your suggestion a go ...
  • pepsundar Oct 31, 2008
    I am using a Proview 17" LCD monitor (700P) which is 3 years old. Since last week, when I turn on the monitor the display comes on; stays for 1 second and goes off, while the power LED is still on. Actually it is not completely off; if you look closer, you can still see the display which is very faint.
    After turning off and on for 10-15 times, then the display stays on until I turn the monitor off.
    Is there any reset that needs to be done or is the monitor at the end of its life cycle?
  • 975 Answers
Does the ON indicator light stays on ? if it does then the problem is a cold solder or burn solder . If your handy , you have to open monitor and look inside the PC BOARD where you ll see a transformer , check for a burn spot around that area , re solder it , and try again , it should be working properly, hope this helps and please rate solution , thanks AJ
Posted on May 06, 2008
Benq fp581 screen goes blank after about half a second evertime i turn on my computer.
Even thought the monitor looks blank check to see if you can see a faint image (shining a flashlight at the monitor sometimes helps). If you can see an image it could mean that the inverter board has gone bad.
I have also heard of an overheated computer causing a similar problem.
May 20, 2010 | Computers & Internet
More likely to have problem in either the backlight light inverter board or bad lamps due to poor solder connections, see
You will need test lamp to narrow down the problem.
Feb 05, 2010 | Computers & Internet
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Upon turning on my computer monitor turns on for only about a half second then goes blank
chances are pretty good that your monitor took a dump
if you have another monitor or borrow one plug it in and see if it works.
that just happened to me and i bought another monitor and all the trouble went away
Mar 09, 2009 | Acer X221WSD Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
Looks like one of your backlights is bad, first indication is the red or pink tint, replacement of the lamp is fairly easy. If one lamp is bad the inverter will not work. You can get a replacement lamp from Mouser electronics for about $12
Sep 27, 2007 | Princeton Digital VL180 18.1 in. Flat...
Monitor Goes Blank after 30 mins....
Dec 12, 2006 | Dell E173FPb 17" TFT LCD Monitor
Computers & Internet Logo
966 people viewed this question
David Payne
David Payne
