Question about Kodak EasyShare ZD710 Digital Camera
My camera won't turn on even after I have put in an a fully charged battery. What could this problem be?
    President:
  • 2,761 Answers
This problem is frequently due to corrosion on the battery contacts inside the camera. Remove the battery and rub the camera contacts firmly with a clean dry cloth or cotton swab. Heavy buildup may require cleaning with a fine wire brush or steel wool. After the cleaning, insert the batteries and see if the camera will power up.
If the camera powers on briefly, the lens zooms in and out, and then the camera powers down, your problem is likely due to lens damage or dust/dirt/lint in the zoom mechanism. A damaged lens will require professional repair, especially if the camera has recently been dropped. A clogged mechanism can frequently be cleaned and restored to working by blowing a stream of air (from canned air or a compressor) around the base of the lens where it meets the camera.
I hope these common remedies work for you.
Bill B
Posted on Aug 27, 2010
Won turn fully charged battery
How long you have the battery? I suggest you to fully discharged the battery and then charge it as much as you can, do this circle for several times. Hope this can help
Jul 23, 2013 | Fuji FinePix A330 Digital Camera
Flashing 0% battery and won't turn on
I had the exact problem with the blinking top menu. I found that my memory card had gone bad. one i put in a fresh card the camera operated normally.
Aug 27, 2012 | Canon EOS 60D Digital Camera
Canon powershot SD1300 IS won't turn on, even with fully charged battery
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Oct 11, 2011 | Canon PowerShot SD1300 IS IXUS 105...
I have a brand new Nikon D3100. The battery was fully charged and placed in the camera. I took about 4 photos, and then turned the camera off. When I turned it back on the battery wasn't working to...
The solution to your problem is simple, Kathrynbax.
The battery never comes in fully charged. It's always charged only so you may be able to check if your camera is working. I suggest, you take out your battery and put it to charge for exactly 90 minutes as the manual says. Then I'm sure you won't face any such problems.
Hope this solves your problem.
Good day!
Rebel
Sep 17, 2011 | Nikon D3100 Digital Camera
I have a Sony AX Digital 100 Camera. I used it yesterday and everything worked fine. Battery is fully charged. Tried to use it today and it won't start. I have taken the battery in and out and even...
Does there is something happened when you turn on the camera? If you can heard sound made by the len or the camera try to open but turn off in a second? If so, there is something wrong with the lens, and this how to fix camera lens error will be helpful. Else, if the camera are without any reaction you can check it the joint of the camera to battery is well.
May 20, 2011 | Cameras
My camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
Camera will not turn on and battery is fully charged
Hi I am Vortash I know this might sound silly but check the battery is in the correct way round .. if your like me and changed the batteries to my easy share I forgot a couple of times and put them in the wrong way round ..( even we make mistakes ) reversersal of the batteries cured my problem and added to my embaressment lol .. other than that check the batteries havent leaked and if they have look in the battery compartment for signs of damage rust etc .. and if you are still using the easy share battery that came with the camera .. it might say it is charged but may not be mine was dead and wouldnt charge afyer about 6 months use .. Regards Vortash
May 17, 2009 | Fuji FinePix F10 Digital Camera
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
Thanks,
Lee
May 13, 2009 | Casio Exilim EX-S500 Digital Camera
It wont work!
if it said fully charge its probably not yet.
could it be that you damage your camera in the first time that it was jammed?
Jun 22, 2008 | Fuji FinePix Z100fd Digital Camera
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Kodak EasyShare ZD710 Digital Camera Logo
107 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
