Question about GE (PSS26MSRSS) Side by Side Refrigerator
Has stoped makeing ice and none of the door controles work. model SH205298
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Aug 28, 2010
Kkitchenaid side by side refrigerator. The ice maker stoped working, but the in door water despensor works perfectly
TRY PULLING OUT THE "ICE AUGER" AND RESETTING THE ICE MAKING UNIT ITSELF,MOTOR SHOULD RESTART AND FREEZE...UNLESS YOU RARELY USE IT,IN THAT CASE YOU MAY HAVE MOTOR ISSUE?? STAY IN TOUCH,LET ME KNOW
Jun 06, 2014 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My samsung refrigarator stoped makeing ice
you could have a bad filter head - PART NUMBER: DA97-06317A
you get water from the door? If you do then your filter head is fine and you almost certainly need a new icemaker - PART NUMBER: DA97-07549B
Mar 24, 2013 | Samsung RSG257AA (241 cu ft) Side by Side...
I have a GE Profile refigerator ( model # PSCS3VGXAFSS ). I have had it for a year. It is still under warrenty. The question that I have is that the ice maker just stoped making ice. It goes through all of...
There is a dual solenoid water valve. One solenoid controls the water dispensor the other is for the ice maker. If its under warranty you should definitely have it looked at.
Sep 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Dec 30, 2009 | Kenmore Refrigerators
Our refrig.& freezer stoped working. i cleaned the coils and vacumed undernead. it worked all night and also made ice but it stoped working again this morning. so i pulled the back of and checked the...
Make sure the fan near the compressor is running and that the coils next to it are warm. If that's not the poblem
Then Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM). If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER NOT WORKING ,MODEL #gss25lgma ww
The problem is most likely the water control valve on the rear of your refrigerator. You can test the ice maker by filling with water and let freeze. If ice dumps then the water valve must be replaced. Your model has 3 different choices of water control valves. If the ice maker does nothing but freeze the water and not cycle or dump the ice then I would say the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | GE Refrigerators
Lynx fridge freezer the freezer is working the fridge has stopped
check if there are frost at the back of the freezer wall, if there is then you have a defrost issue.
if not, check the vents if air is coming out on the fridge side. close the freezer door, press the door switch on the fridge side and feel the air. if there is no air, the evaporator fan could be shut.
if there is little air, check the vent, insert a small rigid wire, push the vent or flapper open and make the air stronger. you have a vent controll problem.
if there are ice in the vent, thaw it out and hope it won't freeze again.
Jan 01, 2009 | Refrigerators
Changed filter, red light flashes, not making ice at all
heatman101
kjkjl
Aug 08, 2008 | U-Line Refrigerator Ice Maker
Thermadore Freezer
I assume you mean do not work? I have the freedom 18" with through the door ice water. Themador has replaced the whole unit already. The second stoped woking after six weeks, call is in to repair again......
Mar 21, 2008 | Thermador Freezer FREEDOM® T24ID80PLS
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
