Question about Air Tools & Compressors
After moving across the country, the compressor never shuts off when plugged in. there is a hissing under the switch at a pin hole below the pressure switch. Also once the compressor reaches 70-70psi. the on/off button wont turn off the compressor. It keeps popping up. It is a Rigid, mini wheel barrel 5 gallon compressor
    Problem Solver:
  • 10 Answers
The pinhole leak is most likely your problem. However pressure switch leaks are often misdiagnosed.
Drain all the air from your tank.
Follow the 1/4" copper or plastic line that connects to the pressure switch back to where it meets a fitting that screws into the tank.
Take the lines off of that fitting and take the fitting out of the tank. That is your check valve. Be sure that isn't leaking or obstructed in anyway.
If it isn't leaking or obstructed I think you need to replace your pressure switch. Without having hands on access to your unit I can't be sure.
Posted on Aug 31, 2010
Will only go to 60lbs of pressure and will not cut off
Its not going to shut off till it hits its set upper limit, There is a check valve that is spring loaded that as the piston pushes air out of the cylinder into the tank it shuts as the piston is going back down to get another load of air to push into the tank. If the check valve goes bad and they do go bad, actually they burn a side off the flat disk inside the check valve that drops over the hole to hold back the air in the tank ,it will let the air chase the piston back down and leave no room for any new air to fill the cylinder. It is a ping pong affect. The size of hole in the disk at this point is small enough to allow you to build to 60 psi and your upper limit is probably set above 100 psi so until it reaches that it will not shut off. I will attach a link to a what it looks like and the ones I buy. Ussaly if you shut it off and place your ear close to the limit switch you will air hissing. That limit switch has a dump valve in it to remove the pressure off the head so it can restart with out being under a load, the hissing is caused from the check valve leaking into the cylinder up the plastic line to the limit switch and out the dump valve.
Mar 13, 2016 | Dewalt D55146 4.5 Gallon 200 Psi Portable...
Lefoo pressure valve leak
Where is it leaking from? If the unloader hisses for a few seconds when the compressor shuts off, it is working fine. If it hisses all the time when the compressor is stopped, it is still fine, but your in-tank check valve is toast. If it hisses when the compressor is running, you need a new switch.
Mar 03, 2013 | Emglo LEFOO Pressure Switch LF10
The compressor air supply line from comp. to storage tank has a tee at the tank with a brass pluss in it with a tiny pin hole and that is allow air to be expelled. Is this a safety plug or can it be...
no, do not block with a solid plug. This allows air to bleed off the compressor so it will restart when pressure switch makes. If air continually bleeds out of this hole i would check the tank check valve . It is bad or has trash or something keeping it from closing. If check valve is bad it will allow air from the tank to bleed down until compressor starts or no air left in tank if shut down
Aug 16, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
Compressor runs and compress air,but when air setting is depleted compressor will not start to compress more air.If you waite it will start some times do think this might the compressor switch
If it doesn't try to start, then it could be the pressure switch. Another suspect could be the thermal overload on the motor. The motor (or just the overload) might be overheating and shutting the unit off, then allowing it to restart when it cools.
Is there any humming, or does it blow the breaker? When ot shuts off, do you hear a brief hiss of air?
If there is humming or breaker blowing on restart, or no hiss of air at shutoff, the pressure switch unloader valve is probably bad. If the air blows off, and there is no humming, and the compressor doesn't reliably start, it is probably the pressure switch. If pressure drops too low, give the pressure switch a tap with a screwdriver. If it starts then, the pressure switch is your problem.
Jun 02, 2011 | Air Tools & Compressors
Ac not working 1996 jeep cherokee country.doesn't put out cold air
You could be low an R134a coolant, compressor might not be working or the pressure sensor might not be working. First thing you need to do is check the compressor look at the front of it and see if the center is spinning when you turn on the air, it should spin when the air is on or the defroster is on, if it is not spinning the R134a may be low or the pressure sensor could be bad. If it is spinning it may just be low on R134a but not low enough for the sensor to shut off the pump.Ok here is how to check if the compressor is (not spinning) Follow the aluminum lines off the AC compressor under the hood until you find the pressure sensor it will have a plug with two wires coming off of it, unplug it and get a 2 or three inch piece of wire like speaker wire or something that has a bunch of small wires in it and not a big solid single wire, strip both ends of the wire and insert them into the plug holes of the switch plug this should engage the compressor if not the compressor may be bad if so let the compressor run for a little while if the ac gets cold the pressure sensor is bad if not it the system is low on R134a which you can get from Wal-mart and do your self. If it does work with the wire and you determine that it is just the sensor you can run it with the wire in it but if the system ever gets low on R134a the pump will not shut off and it can burn out the pump so it is not recommended although i've been running mine like that for about a year now. Please post any further Questions.
Eric
Jun 01, 2011 | 1996 Jeep Cherokee Country
I have a C2006 Type 4 Porter Cable pancake compressor which will build pressure all the way up to 150psi then cut off as it should but there will be a loud hissing and pressure drop until the cut on...
first you have a reciprocating pump and the hissing you ear probably comes from the unloading valve on the pressure switch(it will look like a bike tire valve)if there is air coming out the valve when the compressor is off it probably means you have a bad check valve.This valve is use to unload the pressure inside the pump for an easy start .a motor always drive more amps on start up if you cant unload this pressure you will trip the overload(you probably have a reset button on your motor)check the specs on your pressure relief valve ,its a small pump maybe its just adjusted to high.in this case your pressure relief valve will open .If the pressure is fine and there is air coming out the relief valve then you have to replace it!to adjust your pressure turn the screw on your pressure switch clockwise to increase and counterclockwise to decrease .usually you have a 30 psi between cut-in and cut-off called the pressure differential.It can be adjusted on some pressure switch.be sure you put some teflon tape on the treads if you replace something to avoid air leaks.hopes this help!
Jan 23, 2011 | Porter Cable C2002 150 Psi 6 Gal...
IR SS5L5 Won't reach shut off pressure
It sounds as though your unloader valve is stuck or broken. I would try and repair it but otherwise you will have to bite the bullet and get a new switch assembly I think. As you have just been working on the tank it might just be a bit of debris dislodged and stuck in the unloader valve. The unloader should only hiss just after switch off weather by automatic shut off or by manual shut down.
Jun 05, 2010 | Ingersoll Rand SS5L5 Ir Electric...
Why will the AC of my Town and Country not engage?
could be low of freon ,most cars has a pressure switch so when the system has a leak and loses presure under the rated pressure of the switch it shut it off...it is located on the dryer it will be a 2 wire plug type set up, unplug the ele. plug side momentary and jump it with a jumper wire and see if you hear the compressor clutch kick in if so either the switch is bad or your system has loss freon. could be also something as simple as a blower fuse or relay too ,last but not lest the compressor clutch couldv'e gone bad. to ck that if you are getting fire at that pressure switch and down to the compressor then the clutch is bad or compressor as a whole has locked up but that would make it either throw a belt or burn it off.
Dec 02, 2009 | Fiat 124 Cars & Trucks
Willnot shut off keeps gaining pressure,leaks from under switch box as its running dont leak after you unplug it
On my compressor, the pressure switch has a diaphram that moves with increased pressure to push the switch off. If yours is the same type, and the diaphram has a hole (maybe the leak you hear), it might not move far enough to push the switch off. Something to check. If you take the pressure switch apart, beware as there are springs and parts that will become instantly liberated, and they're difficult to reassemble.
Jun 23, 2009 | Air Tools & Compressors
Clarke hunter 60 2.5 hp compressor , trip switch keeps tripping
if you are talking about the brass valve with a small pin in the middle.it leaks untill the pressure get to 15-25 lbs then the pin pops out and stops leaking and the compressor pumps to pressure. this is normal that valve it a cold start valve that allows the compressor to start with out binding
Dec 09, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
59 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
