Question about Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G
When i turn on my computer the monitor remains in stand by with the screen black and it says There is no signal coming from your computer.
  • 4,102 Answers
Hi the first thing to do is switch it all off at the mains, then unplug everything from the back of your computer then plug everything back in doing this will remove any static build up that could be causing problems with your video card.
then check the cables at the monitor end if they dont come out of the monitor give them a wiggle just to make sure they are not loose then plug everything back in and switch it all on.
if after doing the above you still have no picture then the problem is going to be with the video or graphics card in your computer, if this is the case then the chances are it has over heated if this is the case then replacing the graphics card should solve your problem, if how ever your computer dont have a graphics card and its just plugged into the mother board then this itself may need replacing.
let me know what happens after you have unplugged everything ok
plz rate this solution as i have loads of posts that are unrated taking up my whole page, thanks
Posted on Aug 27, 2010
My desktop pc turns on but will not come up on my monitor my monitor is not faulty as its the same on other monitors ive tried the monitor comes on as if to load but then a little box comes up safe mode...
When the computer starts, you should have white letters on the screen showing the BIOS. If you do have this, restart it and immediately start tapping F8 if you have windows on that computer. This should bring up a menu and on that menu you should see safemode. Select that using the arrow keys on the keyboard. The computer should come up with a screen that is bigger than you are used to. From that screen you can logon if you have to and then you can change the display settings. From what you are describing it seems that the monitor cannot deal with the signal sent from the computer.
Feb 19, 2015 | Computers & Internet
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously.
Your monitor may have an option to set it as "manual" or "auto". If set in manual, you will have to turn off the monitor power switch each time. If it has the "auto" setting , it should shut off or "go to sleep" when it detects no input signal.
Oct 18, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Acer Aspire 5100 laptop's screen remains black at start-up
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
Sep 19, 2009 | Acer Aspire 5100 Notebook
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
Computer monitor screen remains black
try giving the monitor a hot slap or spank at the back, believe me, you'll be surprise, you've got nothing to loose
Jul 20, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
My monitor does'nt work, computer boots up but the monitor is black. What can I do?
when i start up my computer i can hear the sound of the welcome screen and desktop but the monitor remains black with stand by orange light but when i make restart it works normal.
Jan 27, 2008 | Compaq Presario R3000Z Notebook
Lcd monitor failure
your monitor need to be service so take it to service center if you are in mumbai you can call for service
Ashok
9322133048
Nov 11, 2007 | HP Compaq FP5315 15" LCD Monitor
Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G Logo
mukhtar21 shaikh
mukhtar21 shaikh
