Question about Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt
The Master Volume control on my Line 6 Flextone II Head is scratchy-noisy when I turn up the volume. I am looking for a replacement, but, Line 6 does not have it on their replacement parts site. The phone number they have listed (805-379-8900) is apparently disconnected too. They also do not provide the schematic diagram, or, the value of the potentiometer for me to find a replacement at an electronics store. Locating this part would be very helpful. Many Thanks...Mike...
  • Line 6 Master
  • 5,603 Answers
First try spraying a bit of CRC226 (aaaaaa9make sure it is 226 as there are other products with similar numbers there)available at Home Depot in the electrical dept. into the control where the leads go into it. You may need to bend the plastic spout of the spray can at 90 degrees near the end to get it to go up into the control. This has a high probability to solve your problem.
Getting replacement controls that exactly fit are a major headache from anyplace than the original manufacturer.
Posted on Aug 27, 2010
Master volume is scratchy on MG100FX
All i can suggest is to use electrical contact cleaner on it from the inside. But you,ve already done that. And i would imagine that the master volumes will be the same to, Harry
Dec 28, 2013 | Marshall Music
Turns on but there is no volume
If the volume control is analog (meaning it is an old rotary and not digital) - it may just require cleaning.
Pick up a can of electronic switch cleaner.
Nov 13, 2013 | Casio Ctk691 Keyboard
I have a Casio Privia PX-110 electric piano. The volume control is not working properly. How can I get to it to replace it?
Beofore you replace it, if it is only scratchy give it a good working by sliding it back and forth a rew dozen times. (if it is a slider type) If you can get some electrical contact cleaner with a thin plastic tube, try squirting that into it and work it again, if that fails, then look at the volume control replacement.
May 05, 2011 | Casio 88 Key Digital Piano With Stand...
The entire control board on top of the flextone III amp (volume controls, bass, treble, model selector, effects, etc..) is lit up and unresponsive. I tried a factory reset by holding a & d down for 8...
There is probably a power supply failure or with the power on reset circuit. Likely low voltage to the logic electronics. This is NOT DIY unless you are familiar with electronics.
Apr 22, 2011 | Line 6 Flextone III Plus Guitar Amplifier
My Line 6 Spider II 210 won't make any sound from the guitar. When the amp powers on, the speakers pop a little so I know they are connected right. All of the lights are on and the channels can switch...
Bad soldering, especially around the jacks and plugs. Crack in the circuit board. Bad switch contacts on the headphone jack... all these are first things to check.
Here is your service manual for the unit:
http://elektrotanya.com/line6_spider_15w_ii3012_1508_sm.pdf/download.html
Jan 14, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
Scratchy volume potentiometer
Try cleaning your volume potentiomenter with contact cleaner (they come in spray can's), the scratchy sound is audible when you turn your volume control on, the contacts inside your potentiometer accumulated dust or some other particles.
Aug 11, 2010 | Alesis Sr 16 Stereo Drum Machine
Plugged my fbv Shortboard into my Line 6 Flextone iii and all the lights went red with no lcd read out.
Try plugging it in and then turning on your flextone, or vice/versa. If not than post it on the line 6 website, they have techs look at those problems all the time.
May 20, 2010 | Music
I have a Line 6 Flextone III XL. I plugged in my guitar and the sound cuts in and out. It fades in and out. I checked the cable and try using another cable, samething. If I play with the cable by moving...
If the sound "fades" in and out that implies a SLOW change in volume.
If that is what you have, it is likely that there is a problem with the power input or power supply as these are the only thing that would have a time constant to react SLOWLY. Fortunately, this area is one of the easier ones to find and fix.
Dec 07, 2009 | Line 6 Music
High pitched squeal when the input jack is used.
Sounds like your master volume is turned up too much. The channel volume will make the squealing go away(caused by high gain and humbuckers). The best thing to do is dial in your favorite presets and change the channel volume to the correct level with the master volume where you usually keep it. I use my Spider Valve at master volume at about noon and the channel volume between nine o'clock and noon. Let me know if this does not solve the problem......
Aug 22, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Open Questions:
See all Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Questions
Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt Logo
328 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Are you a Line 6 Music Expert? Answer questions, earn points and help others
