Annual maintenance for Toyo Laser 30, do-it-youself
  • marvinf490 Aug 27, 2010
    To my knowledge the Laser 30 heater has no coolant.
  • 22,326 Answers
All you can do is to clean the filter to be honest which is on the front unit if a split unit ,if its a through the wall unit then their is no filter and all you can do here is to remove the front and spray the radiator front with some soapy water to remove the grimey grease that accumlates from tobacco and dust,thats about all
Posted on Aug 27, 2010
    Top Expert:
  • Heating & Co... Master
  • 80,417 Answers
Clean the condensor heat exhanger with water, that is about it, u should never need to add coolant unless the system has a leak
What if you did not bleed the filter when you refire the toyo how do you get fuel back yo toyo
There is a small screw on top of the filter at the barrel loosen it. You may see some bubbles. Do not take it all the way out. If that doesn't work, place something to catch oil under the line in back and loosen the flare nut to see if you have flow or get it started. Do not take it all the way off unless you want a big mess.
nitensheaterservice@earthlink.net or Niten's Heater Service on Facebook
Jan 13, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
Will a monitor exhaust fit on a toyostove?
No. The Monitor has a male fitting going into the stove and a Toyo has a female. The diameters are not the same either. You want a Toyo exhaust pipe for your Toyo. The exhaust is is larger as is the air side. Don't mess around, get the right stuff.
Tom
Dec 15, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Ee2 error on toyo laser 30, how do we access fuel system
I would look outside first. Filter, fuel level and bled the filter. Loosen the fitting on the fuel line and let some of the air out. Do it outside so you don't make a mess inside. After that if you still have a problem check the two red wires that go into the burner. If they don't get hot when you try to start you have an igniter problem.
Tom
Sep 20, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo Stove Laser 30 will not work
The EE-8 indication means there is insufficient air flow to the combustion pot to atomize and ignite the fuel. Check your air switch for a closed condition when the blower is operating.
Oct 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
The blower motor went bad.
toyotomiusa.com/
they have a dealer locator
Tom Hawkins
Jan 16, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Need a service manual for laser 30 toyo stove
Remove the flex hose from the back of the stove. If there is a small hole in the back of the stove, stick a pencil in there and spin the motor. Try to start the stove. If the motor won't spin at all or if it spins freely and the stove still shows an EE8 you need a new motor.
You or your local dealer can change the motor in 30 minutes.
Tom Hawkins
Bethel, Alaska
Jan 15, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo stove laser 30
EE22 means that your Toyo failed to ignite 3 times in a row. You need to unplug it for 30 minutes to reset the circuit board. Then plug it back in, push the red reset button on the right hand side in the little hole towards the back and push the Power button. Your Toyo should ignite after that barring some other problem caused by running out of fuel.
I am assuming that you ran out of fuel which caused the EE2 error code originally. Sometimes, when you run out of fuel you can get water, ice, debris in the fuel line causing an obstruction or limited fuel flow. You may also get an air lock. You may need to crack the fuel line at the back of the Toyo where there is 3/4 nut and bleed the line. If you see no fuel or a small quantity of fuel then you will need to thaw and/or purge the fuel line in order to get fuel to your Toyo's fuel pump.There is also a screen in the sump which can get plugged with rust, debris from the bottom of the fuel tank so you may need to clean the screen in order to get fuel to the pump.
Nov 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Ee 12 code
Hi alaskasteve,
My business is Laser Heating Service in the North Pole/Fairbanks area of Alaska. EE12 is the error code for overheating. Most likely you have a Laser 30 giving you this error code. The most common reason for the EE12 error code is that the Toyo is not getting enough air circulation across the heat exchanger and causing it to overheat. Look at the back of your Toyo where the black frame around the circulating fan and flue pipe is. You will see a screen that slides in a slot at the back of the Toyo. Slide the screen out and clean it. If you have a smoker or the Toyo is in a kitchen area where it collects nicotine or grease then you may need to clean it with hot water, detergent, or 409 Cleaner to get the sticky residue off that the dust fuzz collects on and clog your screen. EE12 can be caused by a couple other issues, but they are more rare. Try this first and let me know if it works! toyotechnician
Jan 15, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo laser 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? The firing process is the burner button blinks green for 7-9 minutes, then it clicks up to the medium, yellow light which starts flashing. That is when the fuel pump starts pumping. If you hear a fairly audible tic tic, or thump thump coming from the fuel pump then that is your indication that the fuel pump is starving for fuel. You either have a fuel line restriction, too little fuel, a clogged filter, a clogged sump screen, or rarely, a failing fuel pump. Usually, it is a fuel line restriction.
If you hear no tic tic or thump thump and it just goes off on EE2 then the problem is in the burn chamber. You may have a carbon chain in the chamber causing the flame sensor to temporarily short out. You can clean the flame sensor, fuel nozzle, and igniter to resolve this problem until you can get your Toyo tuned up.
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
