How to sync the outdoor remote on a Sharp LCD weather station alarm clock
SOURCE: Set the clock
You are in luck. I had to replace the batteries in my DWS-150 & couldn't find the instruction manual to reset the time. Fortunately, I remembered a while back I had the same situation & thought I might have downloaded the manual - while it was still available. Ifound I have it saved as a pdf file on my pc. Here are some excerpts: About the Atomic Clock The National Institute of Standard and Technology (NIST) in Fort Collins,
Colorado broadcasts the time signal (WWVB at 60kHz AM radio signal) with
an accuracy of 1 second per every 3,000 years. The signal will cover a
distance up to 2,000 miles from the source. Like a typical AM radio, your
Atomic Clock will not able to receive the WWVB signal in places
surrounded by heavy concrete or metal panels. The reception of the time
signal can be affected by mobile phones, TV, electrical appliances or other
electronic interference. To get the best performance of the Atomic clock,
please install the home receiver near a window and away from large metallic
objects. If the unit is not working properly, change the unit position. There
may be some interference at this location.
7
DWS-150-IB SP\ENG 10/12/04 11:30 AM Page 7
SETTING TIME
RADIO-CONTROLLED CLOCK
The home receiver will start synchronizing the clock after the 1st channel of
the RF thermometer is registered.
1. At normal mode, hold the “ - ” button located on the back of the home
receiver for 3 seconds to force synchronization.
2. The antenna icon will appear during the synchronization process (on the
right side of the time display).
3. If the icon disappears afterwards, radio time signal is not available at that
moment. Try setting the home receiver in other locations. Remember to
place the unit away from sources of interference such as mobile phones,
appliances, TV etc.
4. Antenna icon will appear on screen if the radio time reception is
successful. The radio-controlled clock will have a daily synchronization at 1:00 am everyday. If previous attempts of reception were
unsuccessful, the home receiver will attempt synchronization
each hour until successful.
5. Each reception cycle is minimum 2 minutes and maximum 10 minutes.
TIME ZONE SELECTION
Press “ - ” button on back of home receiver to select from the following time
zones in the U.S. (zone is displayed in the upper right hand corner of time
display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Time
MANUAL SETTING FOR CLOCK & CALENDAR
1. Hold “SET ” button for 3 seconds to enter clock set.
2. First, select 12 hour or 24 hour setting using the “ + , - ” buttons located
on the back of the home receiver. Press “ SET ” button to confirm.
3. Select Hour - Use the “ + , - ” buttons located on the back of the home
receiver to adjust hour setting. Press “ SET ” button to confirm.
4. Select Minute - Use the “ + , - ” buttons located on the back of the
home receiver to adjust minute setting. Press “ SET ” button to confirm.
5. DST On/Off (Daylight Savings Time) - Use the “ + , - ” buttons to turn
DST on or off. Press “ SET ” button to confirm.
Now you will select the calendar settings-
6. Select Year - Use the “ + , - ” buttons located on the back of the home
receiver to adjust year setting. Press “ SET ” button to confirm.
7. Select Month - Use the “ + , - ” buttons located on the back of the
home receiver to adjust month setting. Press “ SET ” button to confirm.
8. Select Day - Use the “ + , - ” buttons located on the back of the home
receiver to adjust day setting. Press “ SET ” button to confirm.
9. Select Fahrenheit/Centigrade Temperature Readings - Use the
+ , - “ buttons located on the back of the home receiver to toggle
between Fahrenheit or Centigrade readings. Press “ SET ” button
to confirm.
Posted on Apr 16, 2008
  • 3 Answers
SOURCE: 3M Precision Digital Atomic Wall
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Posted on Jan 15, 2009
SOURCE: Lexibook Meteo Clock Weather Station needs resetting - help!
Manuals online at http://group.lexibook.com/index.php?option=com_content&view=article&id=87&Itemid=105〈=en
Posted on Nov 19, 2009
SOURCE: How do I set a seth thomas weather station from a
Press and hold the mode button until the year starts flashing in the upper left. Tap the mode button 3 times. You will see "24hr" with the 24 flashing. Press the + or - button on the back. Press the mode button 4 more times (or just leave it alone for about 30 seconds and it will go back to the normal display).
Posted on Apr 08, 2010
SOURCE: I have a Sharp SPC502
Try pushing the reset button on the inside of the battery compartment of the remote unit then push the reset button on the back of the main unit (you'll need a paperclip or tooth pick to push the buttons). If that fails I'd start from scratch by removing the batteries from both the remote unit and the main unit then replace the batteries to the remote unit first and push reset, then replace the batteries to the main unit and if necessary push the reset button on the main unit too. Hope this helps.
Posted on Jan 02, 2011
How do I set the time?
An atomic clock should set itself automatically using a time server. That is the whole idea.
This may be the manual on it?
Sharp SPC900 Instruction Manual
Feb 10, 2016 | Sharp Atomic Weather Station Alarm Clock
I need manual to set sharp weather station spc403
You should be able to obtain one from Toshiba's website.
Mar 14, 2014 | Sharp Atomic Weather Station Alarm Clock
My remote sensor Tx14TH-LCD-B started flashing several days ago and I have gone thru the factory reset new batteries and decided to buy a new sensor then discovered they have been discontinued along with...
I assume you have tried removing the batteries at both ends, reinstalling batteries at the sensor end then the indoor end, waiting without touching anything until the outdoor temp registers and heaving a sigh of relief as things are back to normal. I also assume since the word atomic is in the header that you have an atomic clock function. If nothing works or doesn't work right you probably need to replace the system.
I have a much simpler LaCrosse system which, at this moment, is showing an outside temp of 56 degrees BUT the clock doesn't work and failed early on. I share your frustration.
Nov 04, 2013 | La Crosse Technology La Crosse S98642...
The outside temp is not displaying
If the clock uses a remote temperature transmitter, you may need to replace batteries.
Jan 12, 2013 | Sharp Atomic Weather Station Alarm Clock...
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
I'm trying to find a manual for my weather genius EM3302A indoor/outdoor remote thermometer, purchased from XS Cargo. I need the manual to tell me how to change the clock from a 24 hour clock to the 12...
Weather Genius EM3302A Remote Weather Station
Once all settings are complete you press the UP button to toggle back and forth between the 24 hour clock and the 12 hour clock.
Sep 23, 2010 | Vacuums
jasbo
jasbo
