Question about Dell (Fan Only) M/N AFC0912DE, DC12V, 2.50A, D/N P2780 P2780
I have a dell 8400 tower that operates just fine usually but lately there seems to be a fan issue where it sound like a jet engine and I am concerned that the fan will fail (it currently operates) and overheat my computer. I have isolated the sound and deteremined that the fan on the heat sink is going crazy and making a sound like a jet engine. I dont know if the fan is going bad or the motherboard is "telling" the fan to go in overdrive. Could it be software, motherboard, some other controller I am not aware of or simply the fan? Please help! Thank you!
    Sergeant:
  • 223 Answers
The bios monitors the processor Temperature and increases fan speed if its gets hot. I recommend, get a can of air and blow out the processor's heat sink, as it could be getting dirty and preventing air flow for cooling. otherwise you have some software that running the CPU at a high rate for a long period of time. Use control +alt +Del then switch to task manager, if you click on the CPU heading it will order the tasks by CPU usage, look for the ones that are at the top of the list. note:system idle process should always be way up there 95-100% CPU, this on is OK. all else look into. you can "end task" one the offensive one and look up more details on the web about that application. I look forward to your comments. Thanks
Posted on Aug 27, 2010
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Does my response answer your question? do you need further clarification or help? Please use the solution rating if your problem has been solved, make a note if your still having trouble.
    Thanks! Gurvy
Dell 8400 dimension desktop on start up the fan runs at top speed like a jet engine taking off, and power light is constant amber with a blank screen. I have removed ram and grafics card etc and replaced...
Your power supply or motherboard has a problem. You can try getting a power supply on the internet ( $25 to $75) first. If no go then motherboard (about $100 to $200 ). The 8400 is about 6 years old which is the average lifespan of computers. One last thing you can try is removing the heatsink assembly and re-seating the processor. You have to clean the old thermal compound from the CPU chip and heat sink and reapply the compound (thermal paste). You might be better off buying a new computer from Walmart.
Feb 26, 2011 | Dell Dimension 8400 PC Desktop
CPU Fan sounds like a jet and computer won't start
It sounds more like the hard drive, the fan has nothing to do with your computer booting up. If the hard drive is starting to go bad it will not boot up, that's what it sounds like your computer is doing. I recommend checking out the hard drive and replacing it.
Jul 02, 2010 | Dell (Fan Only) M/N AFC0912DE, DC12V,...
Dell PC Fan Running like a race car
Hey Darrick, It seems that the fan is full of dust or gone bad. You can open the tower and use a compressed air can to clean out the fan. if cleaning it does not help call Dell sales and order a new heat sink fan.
Jul 28, 2009 | Dell Computers & Internet
Dell Dimension 8400 Start up Fan Noise
Might be a hard drive issue. I had the same problem with one of My desktops. I replaced the hard drive and it worked fine.
Jul 01, 2009 | Dell Dimension 8400 PC Desktop
Dell 8400 steady amber light, no diagnostic LEDs, high turbo fan
you will need to change your processor is like it is bad.
Apr 04, 2009 | Dell Dimension 8400 PC Desktop
Dell dimension 8400
IT MEANS that the processor is not getting cooled enough, try turning on the comptuer with the side panel open, dont reseat the cooling tower, however also check for the four lights on the back of the tower and post the same,,
Jan 25, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400
I have this exact problem.
The Dell Dimension 8400 will seem to randomly go into fan-jet-turbo mode on power-up and fail to boot. The problem I'm referring to is not a heat problem which an over-speed fan might otherwise suggest but a hardware problem the details I'll get to in a bit
I've done all the normal and obvious stuff that has been reported before
remove/replace memory
remove/replace AGP video card
removed all extra power loading / drives / USB etc
BIOS tweaks/resets
check supply voltages with a DMM (I even re-adjusted the hipot to get the right voltage - it was a little low)
As an engineer it is important to determine root cause. Do to this it is necessary to find a way to make the problem occur and not occur. If you're able to do this you can fix it.
Well in my case the problem it related to a mechanical stress on the heatsink. What I mean is a little force pushing the heat sink toward the fan turns off the problem (boots normally) while a little force in the directly away from the fan turns-on the problem (fan-jet-turbo-mode).
The root cause is could one of several things, it could be a damaged motherboard with a broken trace, it could be a socketing issue,
The Fix (not really - just a band-aide) was to use a tie a couple of small tie-wraps through a some small holes in the heatsink then through the fan mounting holes.
Only slight pressure is necessary - too much will likely cause permanent damage. The fan is mounted on rubber isolators so it somewhat limits the force on the heatsink
Any this mechanical issue is somewhat supported but all the information I've read - how removing/replacing the CPU can fix the problem, changing memory, removing cards - all these mechanicall stress the motherboard and likely move the heatsink some.
Intermittent problems are the worst to debug!
Ross
San Jose, Ca
Jul 02, 2008 | Dell Dimension 8400 PC Desktop
Dimension 8400 will not boot, very loud fan.
I have a small business where I have worked on PCs for the past 14 years. I have had some of my clients that have brought me a few of these Dell 8400 to work on with the same problem. Will not boot and loop the start up, along with sounding like a leaf blower. After much trial and error i.e. Heat sink,cooling fan, power supply and motherboards. The first one I worked with by changing the heat sink, worked for about a week, then started doing the same thing. Replaced the Power supply with no results, same issue. Next was the Motherboard, still same issue. Last I pulled the processor out and found that the processor had over-heated and was damaged. In all I had well over $500.00 dollars invested and countless hours. Still the machine did not work, and still needed more work. Since this time I have had a few more of these machines cross my path. My suggestion is to scrap it and purchase a new PC. This is not one of Dell's better designs, and there is a tech issue from Dell related to this problem with the heatsink and the machine itself in the tech support on the Dell site. It states that they had a bad batch of heatsinks, but only replaced them under warranty.
Salvage what you can and build or have someone build you a clone.
Apr 04, 2008 | Dell Dimension 8400 PC Desktop
8400 tower case Broken
You can search it on ebay website for that.
Oct 22, 2007 | Dell Dimension 8400 PC Desktop
Computers & Internet Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
