I changed the new toner but Its still print out empty page , I thought that is the scanner problem , I tried to send fax to other machine and Its came out perfected , so the problem is in the printing system , since this model there are no print head so its not the dirty head neither , Please any idea I should check its it out !! Thank you Huot Fujita
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
There is a service update from Canon, where a part needs to be change in the laser area. You can try to slam the toner door shut to see if it changes it temporarily, but a laser shutter arm needs to be changed.
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
If the paper feeds through but nothing is on it, it indicates that the toner is not being properly fed. Go to this link, type "printout is blank" in the Search window and click the search button. Next, click on the "Printout is blank" line, and review the document. Especially check that you have removed the seals from the toner cartridge (see steps 7 and 9 on the second part).
We had the same problem with our mf6550 printing blank pages after we changed the toner cartridge. I called the support desk today and they said it is the shutter. They told me to remove the toner cartridge and then (without a cartridge in) close the door briskly. Then open the door, install the cartridge and again close the door briskly. It worked! He said it may be a permanent fix or it may act up again. He also said I could take it to a service center to have it fixed permanently. The service desk # is 1-800-828-4040. They can tell you where the nearest service center is. Good luck.
