Question about Whirlpool GU2400XTP Built-in Dishwasher
Water is sitting in bottom after cycle is done.
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Aug 28, 2010
After a wash cycle, there is water sitting in the gasket around the door. This water smells after a few days. What is to be done?
Make sure the washer sits level front to back and side to side. Wipe away any water and leave the door ajar to let the inside dry out. If the whole washer insides smell, run an empty cycle with hot water, detergent, and baking soda to refresh. Hope this helps!
Oct 17, 2010 | LG WM-2277HW Front Load Washer
Moved into home and dishwasher runs threw the cycles...does not spray water on dishes water sitting in the bottom?? Something blocked or not connected?
check if there is water at the bottom of tub when it's going through the cycle. If there isn't, i'd suspect a burnt out water valve
Mar 29, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Water does not drain. does not sound like pump is running. drain lines are clear. do i replace, do i repair.
That will depend on how old your dishwasher is and how much repairs have already been done to it in the past.
So it appears the water just sits at the bottom at the end of the wash cycle - is that right?
Not sure what make or model the dishwasher is, but are you getting any error codes or flashing lights?
I could look into the problem further if you can provide more details.
Jan 20, 2010 | Dishwashers
The clothes are still very wet when the cycle is done, and there is a little water sitting in the bottom of the machine. Is something wrong with the spin cycle?
does the drum turn on high spin if it does is there a low and high for the spin also check the filter which should be located at the fort bottom of the machine it might be blocked
Oct 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a GE WBVH6240HWW Front load washer. I
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
Feb 24, 2009 | General Electric WBVH6240HWW Front Load...
Water sitting in the bottom of washer, and will not cycle
Check your vent drain or your Garbage disposer connection and make sure it's not plugged.
Nov 21, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Soap problems
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some (quite some) water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Oct 21, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Dec 18, 2007 | Washing Machines
Whirlpool GU2400XTP Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
