Question about Cuisinart DGB-600 Coffee Maker
Can i clean my coffee maker with vinegar? if so, how?
    Scholar:
  • 176 Answers
Hi. Just like making a pot of coffee w/o the coffee. Run it through 3-4 times. Then run water through to rinse it out. 2 times.Good luck. Ron
Posted on Aug 27, 2010
How to descale keurig elite 40 coffee maker with vinigar
Unfortunately you will need to use vinegar. The acetic acid in vinegar is strong enough to clean most brewing machines.
Use distilled white vinegar.
Aug 17, 2014 | Keurig Elite B40 Coffee Maker
How to clean keurig coffee maker
It might be time to clean your keurig. Fill the water tank with vinegar and run through about 5-6 glasses leaving time in between to let the vinegar clean. After running all of the vinegar through it should be brewing regularly again.
Apr 28, 2014 | Keurig B60 Coffee Maker
Cleaning inside tank
putting vinegar in the tank OCCASIONALLY wil help to keep the tank and associated tubes clean, but it shold be noted that doing this too often will corrode the aluminum tubing used in the coffee maker. put about a cup and 11/2 of vinegar in the tank and run the coffee maker, followed bu a double run of pure water to clean out the vinegar. should only be done about once a year as vinegar is a mild acid.
Feb 13, 2014 | GE Coffee Makers & Espresso Machines
Can I put vinegar in the coffee pot to clean with the filter in also?
Yes you can clean with vinegar I always hv..no filter tho and u must run water through it at least twice after the vinegar
Jun 25, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
Our coffee maker is only brewing half of the amount of coffee it should. Half way through the brewing, it shuts off. We've cleaned it with vinegar, but it still happens intermittently. It's actually...
Run a 1/2 pot of vinegar through it 2-3 times (I reuse it) and then run water 1-2 times to get the vinegar smell out. This cleans the mineral deposits from your water that are clogging it.
Dec 13, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Self cleaning the quisinart coffee maker
I always use a mixture of 50:50 of cold water and white vinegar to help clean the internal parts of any minerals and scaling.
Unplug the coffee maker first, then add the water/vinegar mix to the reservoir.
Place a new, clean paper filter in the basket to help catch any deposits that will be dislodged and cleaned from the coffee maker.
As far as having the coffee pot dry, there is no need for that. I do tend to wait about 15 minutes to let the cleaning mixture disolve any deposits in the main water reservoir and then I turn on the coffee maker and let it process the water/vinegar solution through it.
Once it's done, turn off the coffee maker and discard the solution in the pot. And rinse out the coffee pot/carafe with clean, fresh cold water. Remove and throw away the used paper filter element andrinse out the basket with warm water and put it back on the unit.
Now fill the coffee pot/carafe with fresh, clean water and pour that into the coffee maker's water reservoir. Put in a new, clean, paper filter and turn the unit on and run a plain pot of water. This will help to clean out any remaining residue and clear the unit of the vinegar taste and odor.
Now you're all set to start making fresh tasting coffee again. I always recommend using filtered water for the best tasting coffee, as the taste is a direct result of brewing temperature, water purity, and the coffee you use.
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Cuisinart DCC-1200 Coffee Maker
How can we clean our saeco pot.
White vinegar will work well. After you run the vinegar through, run about 2 pot of water through it to rinse. This should do the trick.
Dec 24, 2008 | Saeco Odea Giro Plus Coffee Maker
Kitchenaid coffee maker giving me error 2
Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting!
To clean hard water deposits from a coffeemaker use distilled white vinager. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinager and run through machine as if making coffee. Repeat this process several times using fresh vinager until it comes out clear. Do this once a week and your maker will work much better.
Jun 16, 2008 | KitchenAid KCM511 Coffee Maker
Err 2-repeatedly unplugged, turned on/off, pressed all buttons. NOTHING>
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR!Put a tiny bit of vinegar in the carafe and fill carafe the rest of theway with water. Run that vinegar/water through machine. Using anothercontainer, fill machine with plain water and run that through. Repeatuntil the vinegar taste is gone. If you do not run lots of plain waterthrough the machine after, your coffee will tastelike...um...disgusting!
To clean hard water deposits from acoffeemaker use distilled white vinegar. You may need to use as much asa gallon if the scale buildup is really bad. Fill clean coffee potone half full of vinegar and run through machine as if makingcoffee. Repeat this process several times using fresh vinegar until itcomes out clear. Do this once a week and your maker will work muchbetter.
May 30, 2008 | KitchenAid KCM511 Coffee Maker
Cuisinart DGB-600 Coffee Maker Logo
47 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
littlechum55
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
