TOTALINE Thermostat "Easy Stat" P/N 1241, seems dead! No letters, light, nothing. Need to replace it. it doesn't seem to be easy to remove from wall mount without destroying it. Looking forward do replace it and instructions to have it removed.
the dr
  • 447 Answers
SOURCE: belt replacement
I Can help ..... Remove 2 phillips screws under lint filter pull top of dryer forward and then raise like hood of a car Remove 2 5/16 Hex screws holding front on dryer Disconnect door Switch let front hinge down a tiny bit and up and off Belt is routed with idler hinged into base of the dryer 2 slots
Posted on Oct 05, 2007
shaggyrat
  • 1224 Answers
SOURCE: remove tv from wall mount
there is an anti theft device on the wall mounts you need the manual to adjust mount to take off
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=255670bad135aec3653b726b698def9d&q=Samsung+PDP4294
heres the link just follow instructions to get download i will also be posting it here on fixya too
this the manual
Posted on May 26, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Fuse location on wall mounted Whirlpool MH7140XFQ
The fuse is in a holder located behind the control panel assembly.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, you can download it here.
If the oven is dead, it may also be a bad magnetron thermostat or oven cavity thermostat.
The first one can probably be accessed through the opening behind the control panel, but the oven cavity thermostat cam only be accessed by removing the oven from the wall, then removing the outer cover.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 23, 2008
  • 337 Answers
SOURCE: 1997 Mercury Villager Thermostat Replacement
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c15280091cd8
Posted on Dec 07, 2008
  • 5 Answers
SOURCE: How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Posted on Sep 12, 2009
Totaline thermostat P274-0200 just stopped working...can't figure out why,
check condenser fan line. over heat condenser so have not cooling in home.no cooling so Thermostat not worked.if it's ok. check Thermostat volb lick .
May 28, 2012 | Carrier Totaline P291-1003 Capacitor 10mfd...
My honeywell thermostat is asking for heat but the furnace won't turn on.
The first thing i would do is to make sure the t-stat is good.One easy way to do this is to remove stat cover then remove the screws that hold it to the wall. Disconnect t-stat wires making sure you note location. There should be a red and white wire for heat so put these two together and if your furnace comes on then the stat needs replaced. If it does not you need to check further to make sure you have power to your furnace.If the furnace does come on with these two wires together the furnace will run non stop. Hope this helps you. Thank you
Jan 12, 2011 | Honeywell Programmable Thermostat Heater
What is easy way to replace the thermostate in
Hi, that thermostat should be a wall mount. This heater has only 2 wires and any "Heat only", "millivolt" thermostat will work. Remove the old T-Stat and mount the new one on the wall, only 2 wires and less than a volt so no shock danger, doesn't even matter which wire goes where. Good luck and comment back if you need any help.
Jan 09, 2010 | Cozy Heating & Cooling
Hotpoint fridge freezer icing up freezer and fridge does not work
Does your model have independent thermostats for the fridge & freezer???
If not, could be that you will need to change the Thermostat.
These are not expensive - around £10 if you buy on the Internet.
Easy to fit yourself...just turn off the power, remove the power plug from the wall, then unscrew the 'stat unit from inside near the top of the fridge (some are attached to the interior light) and remove the screw holding the thermostat tube to the rear wall.
Often the thermostat gets a small hole somewhere in the long tube, which then lets all the gas escape, making the stat useless.
You can see these small holes in the pipe if you use a magnifying eyeglass, like the kind Jewellers use.
Nov 17, 2009 | Freezers
Totaline Thermostat either P/N 474-0100 or -0220
The power outage probably caused the thermostat to go back to factory default settings. You need to go through the advanced setup procedures in the owners manual on page 6. This will allow you to turn the heat pump back on.
Oct 05, 2009 | Heating & Cooling
Is there a battery in T8000C
no batteries in this one it uses a cap. to maintain the program. Did you remove the stat to chech for batteries? If so check the alignment of the six tiny pins on the sub base as they are very easy to bend when re installing the stat. If you did'nt.
Check for power at the furnace. If neither one is the case, I have replaced many of this stat with a Honeywell Focus Pro 6000 stat
Dec 27, 2008 | Heating & Cooling
Smeg ovens
quite easy. take oven out and remove top plate. you will see stat behind the temp control knob - usually just clipped on(sometimes stat becomes unclipped which will cause your problem as well)
remove stat and undo capilliary from mounts inside oven. reassemble in same way. note where wires go before you remove them!
Feb 26, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Computers & Internet Logo
438 people viewed this question
David Payne
David Payne
