Question about PowerLogix 1.2 GHz PowerPC G4 (pfd1.2g100) Processor Upgrade
PowerPC G4 (1.2) running slow on normal computer usage and internet surfing. CPU temp is running at 106 to 110 deg F. What can I do to speed up Machine. (512mb ram)
  • 4,102 Answers
Hi their isnt that much you can do you need to check whats running on your computer and delete software you dont need as having this running in the background will slow it down loads, the only other option you have would be to install more ram or even a new processor.<br /><br />if you go to www.crucial.com<br />then scan your computer on their site it will then tell you how much ram you can install i use this site when im building computers.<br /><br />let me know how you get on or if you need further assistance ok<br /><br />plz rate this solution as i have a whole page of unrated posts, thanks<br /><br />
Posted on Aug 27, 2010
Frozen Laptop
If it is not overheating, try running the free version of Advanced System Care.
Speed Up Slow Computer Keep PC and Internet Secure Freeware Download IObit
Sep 11, 2015 | Toshiba Computers & Internet
I turn on the computer and it may run some times for about 10 or 15 min. and then shut down i was wondering if i need a bio's update or what i have two hard drives in the computer xp pro on 1 and vista...
It could be overheating. After it shuts down, restart it, and enter BIOS SETUP, and look for a "PC Health" or "Status" entry on the menu. If you're lucky, it will report the current CPU temperature, and the speed of the fans, and the settable temperature at which it will shut itself down.
Check the capacitors on the motherboard -- any capacitor with a "dome" on top, instead of perfectly-flat, is a leaking capacitor that is intermittently failing.
Jul 19, 2011 | Mach Speed (MSNV-939) Motherboard
Computer is slow to open file when connected to network
when connected to a network the cpu performance get highe, check your cpu performance by press control alt and delete on your keyboard at the same time to go to windows task manager, see the cpu usage by clicking performance, if the cpu usage is above 50% it means that wasn't normal, run a virus scan to make sure that your windows is free from viruses, if it can't fix your problem it mean you need to reinstall your operation system
May 12, 2011 | Acer Computers & Internet
Internet speed problem
Use the below steps.
1. Internet Speed Problems caused by Binding too many Agreements on Network Card
Slow internet surfing speed is a usual problem among LAN users because there are too many agreements binding on the Network Card. If a NIC is bound lots of agreements then the computer has to spend more time on identifying which agreement would transmit a certain group of data that passes it. PC users will feel uncomfortable at the moment when they are surfing the Internet. Here is a solution for this situation: a. Use a Network Card to run only PPPOE agreement to connect ADSL; this will provide the exterior connection of internet. b. Use another one to run other agreements in order to boost its performance so that the speed of internet surfing would be improved obviously.
2. Internet Speed Problems caused by Unbound TCP/IP Agreement.
Unbound TCP (Transport Control Protocol)/IP (international agreement) may be caused by reasons as follow: a. the driver of Network Card is installed incorrectly. b. There is a problem with quality of Network Card. c. PCI slot is broken. Solution for this situation: You should uninstall NIC driver in the Device Manager at first----reinstall the driver after you reboot your computer. If you still fail to improve the internet speed with this solution, please change a PCI slot for Network Card or change a new one.
3. Internet Speed Problems caused by low quality of telephone line.
If the phone line is affected by some bad extraneous factors, network device will adjust client access rate automatically and dynamically according by the quality of line and transmission distance. The Internet surfing Speed also will be affected by the export bandwidth, the website line from opponents and the device configuration if you try to visit foreign website.
4. Internet Speed Problems caused by too much installed Internet Explorer plug-ins.
Internet Explorer plug-ins would be installed or loaded on your computer automatically when you open Internet Explorer and visit website. Surfing speed of course will be slowed down by too much Internet Explorer plug-ins. It is highly recommended to use some optimization tools to optimize your speed of Internet and clean some disused Internet Explorer plug-ins to speed up Internet surfing.
Nov 10, 2010 | Computers & Internet
I've had several memory dumps. It restarts on it's own whether playing a game, running programs, surfing the internet, or even just at idle. The temp of the cpu and the the dual video cards is running...
Your temps are normal. This sounds to me like you may have some failed/failing capacitors on your motherboard. If you have a look at the board usually near the CPU you will see a few small cylinders. These capacitors should have a completely flat top. If they are bulged up even a tiny bit or having any leakage they will cause major problems. Luckily you can purchase replacement capacitors for a very small cost and have them replaced by your local electronics repair tech if you have one.
Oct 17, 2010 | Computers & Internet
Cpu running slow, even causing audio to chatter.
Yes it may affect your speed so whenever you sit on your pc just clean temporary file
  • start
  • run
  • type %temp%
  • tap enter and delete all the files
by this the speed can be improved
May 14, 2010 | Computers & Internet
The game slows and speed up back to normal speed
yes.
this is happening due to less memory availability
just download and install IOLO SYSTEM MECHANIC (you may download trial) run it and everything will be automatically corrected.
Jan 26, 2010 | EA Sports Cricket 07 for Windows
Pc working slow. i have done disk clean up deleted temp files .scanned pc with 3 antivirus but none detected any threat .i have 1 gb ram and 80% free hard disk space.i have downloaded ccleaner and fixed...
Dear Sir,
go to hyttp://xviruslab.blogspot.com and go to System Utilities find PC Booster download and install and run a auto run it will clear all your problems
bye bye
keerthy
Sep 29, 2009 | Computers & Internet
Daytona 955i running hot
That is quite normal - these bikes run very hot and will typically reach temp where fan kicks in (103 deg C) while bike is sitting at idle, even if not particularly hot weather. Needs good airflow through the rad to keep the temp down.
Fortunately, when fan comes on it lowers the temp quite quickly.
Jan 07, 2009 | 2006 Triumph Daytona 955i
Slow
Hey
There can be many things that can cause your computer to slow down.
First of all Viruses .. some viruses once in the computer are difficult to be recognized by normal anit-viruses they generally make your computer go slow, such a problem can be solved either by getting a better anti virus or by formatting your system
There can be another reason... have you check how many processes are running on your comp?
ctrl + alt + delete go to processes... now a normal XP os needs only 17-20 applications to run properly ... so anything in excess to it is being run on your computer to provide some sort of service to you(you must not start stopping those extra processes w/o knows what they are doing).Try closing some of the applications this should make your computer work faster
There can be another reason... the drive space in your OS drive Say Drive C is very less ... should be above 500 Mb for smooth functioning.. in such a case delete unwanted files..
for further assistance feel free to mail me at
kushalagarwal22@gmail.com
Cheers
Kushal
Aug 27, 2008 | Dell Inspiron 1100 Notebook
PowerLogix 1.2 GHz PowerPC G4 (pfd1.2g100) Processor Upgrade Logo
49 people viewed this question
Top PowerLogix Computers & Internet Experts
David Payne
David Payne
Are you a PowerLogix Computer and Internet Expert? Answer questions, earn points and help others
