The tv works once we have got it on standby, but when we turn the power of at the mains it takes ages and a lot of patience to get it back on. what is the problem
  • 8,457 Answers
Power supply board,that the board,where the power a/c cord plug into it.Have these parts call capacitors,they are dying,have bulges on it tops or puffing on it tops.These capacitors are dying and have leakages of gases not giving fully charges to the power supply board.Have tools like soldering iron,desoldering pump and solders.U know basic electronic's,buy those same value or a bit higher voltages,but must have the same microferet,replaced thesse dying leakages capacitors,ur tv will power up and down right away.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Aug 27, 2010
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
If my television is turned off then when turned oin it will come straight back on but when its been turned off for aboutn an hour it takes ages to get it off standby can you help ty
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 05, 2015 | Televison & Video
How do i fix my tv, from standby it won't turn back on if you keep trying about 50 times it will eventually come on???
Mar 08, 2015 | Televison & Video
JVC TV turns on from standby the returns to standby after 30 -40-50 mins then back on after a few mins then standby after about 3 mins etc.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Check for any loose solder terminals at its main power regulator section circuit. Re-solder all the suspected solder terminals; by applying a little more solder to each terminals. The fault is with any loose solder terminal/s at this circuit stage.
Nov 19, 2014 | JVC Televison & Video
My tv doesn't turn on. Once I power on. The green
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 05, 2014 | Televison & Video
I cant get my tele to work as it wont come off standby
Sounds like a power supply issue. You can try a "static discharge" and unplug all power to the TV, hit the power button a few times... and then plug it back in to power. If it works - great, but if it goes back to standby, there is something wrong with the unit - OR - its not detecting a signal and turning itself off.
Let me know if that helps.
Jason
May 09, 2014 | Televison & Video
I have a waltham tv3202hdv which takes ages to turn on,,the standby button flashes for ages then when it stays on and i try to switch the tv on the green power light flicks on then goes back to the standby...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 02, 2014 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Lg tv well not turn on
If the standby light is ON, and the set does not power up by pressing power switch at the remote control, or at the side panel power switch, the main board is faulty. If there is no standby light, the power regulator board is faulty. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 12, 2014 | LG 42LG50 42 in. LCD HDTV
Can't turn on
When you turn the MAIN off you are killing all power to the set---Some advice---If you Google the model number of this set with the word problem after it you should find what I have seen a lot in these sets: they develop bad solder connections on the power supply printed circuit board---usually the board is about 18 inches tall and 12 inches wide--A number of sites online offer to have you ship them the board and they will resolder it for you.
I have repaired about 12 of these with this problem in the last 2 years---The board has to be removed(there are quite a few plugs that need to be labeled and removed and lots of screws that secure the board in place.)
Maybe not a job for a do it yourself person but the soldering (if it is your problem) will take about 45 minutes(including removal and installing board back).
Like most modern sets this set uses lead free solder and it is soldered(the boards) in a wave or one step process---over time from heat and expansion some connections may crack or even break loose----I would look at the POWER SUPPLY board(follow the power cord as it goes right to it)
If you have any questions or need help please contact me here.
I do this here for free so if this information has helped you take a minute and give me a vote here.
SD TECH
Sep 06, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
