Read out is partail (missing digits) - Computers & Internet
    Scholar:
  • 100 Answers
Read out is partial on the monitor?
Might be a one of a few things:
1) Bad monitor cable (replace)
2) Cable not plugged in well (check plug)
3) Video card is failing
4) Monitor is failing. (try on another PC)
If you try your monitor on another PC using the same cable and all is good, then I'd assume that your video card is failing. Requires replacing a video card. You might need a place like Geek Squad or a techy friend/relative to assist you. This isn't tough if you know what you're doing.
If there are still issues when testing with the other PC, then it's either your cable or the monitor itself. Try getting a replacement cable. If the same issue still exists, then it's your monitor that's going bad. If everything is now good, then it was your cable that was bad.
If this information has been helpful please remember to give me the appropriate 'thumbs up'. Thanks, and good luck!
Posted on Aug 27, 2010
I received only a partail shipment toeay 4/3/2018. The four cameras were not included in the package shipped. Only the Dvr was included.
You have mistakenly posted information on the FIXYA web site.
FIXYA is a service by unpaid volunteers using the internet to ask and answer questions.
Please ask a trusted relative or friend for assistance with your issue as FIXYA cannot help you.
Apr 04, 2018 | Cameras
Digital dash gauges all read zero, onstar not working...
for nothing on the dash to work ,it indicates that a ground wire is missing, broken or the ground point is rusted
Could be the BCM unit so run the fault codes as well
Jan 24, 2016 | 2011 GMC Terrain
I have a RCA projection tv hd52w59 theres a partail static screen and a red green and a blue line in the middle
is the line horizontal or vertical ?
you have some sort of a deflection problem its either vertical failure or the yoke return circuit on the horizontal has a failure
Jun 01, 2014 | RCA HD52W56 52" Rear Projection HDTV
Computers can't read the files on my camera. what is the problem of that?
Codecs missing, or drivers for camera not present on the computer. How do you try to read your files? Are you using a separate card reader or connecting the camera using a USB cable?
Jun 05, 2011 | General Electric A1250 Digital Camera
My Polaroid a300 Digital Camera says to make sure you format the SD card in the camera before you use it in a computer. I see absolutely no option on this camera that will enable me to format the card. Am...
I'm sure you aren't missing something. Have you tried to take a picture and connect your camera to your PC ? if your PC don't have any problem to read and copy the picture, I think you can just ignore the notification.
But if you got any problem, like your PC can't read your data in your camera memory, than this formatting would be necessary. Not via camera of course, but via PC. If you can connect your camera to your PC and the memory card read as removable disc, then you can format it from Windows Explorer. But if you can't, take off the memory card and format it via car reader. And I suggest you to format before you take any pictures because formatting process will erase all of your data inside the memory card.
Hope this help and be kind to rate please.
(^_^)
Jan 06, 2011 | Polaroid a300 Digital Camera
System files were missing
plz tell me how i can restore iriver h10 4gb i can on my mp3 plyer then i read screen he tell me system files missing u can restore but how i can restore plz tell me?
Mar 19, 2010 | iRiver H10 MP3 Player
Pictures missing
could be true... microwave uses a small magnatron, it not important what it does, whats important is that a magnatron creates a strong magnetic field. this is something that the memory card in your camera would be susceptible to. since the memory card uses tiny magnetic pulses to read and write data.
Mar 13, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Heater problem
sounds like you don't have enough coolant flowing into your heater core. Check coolant level in radiator and overfolw bottle.
Or, you have your temperature blend door stuck in the cold or partail cold position. Could be a bad blend door motor or heater cntrols head.
Dec 14, 2008 | 2002 Ford Windstar Cargo
Missing pictures
Hey flowernthe,
The error message “card cannot be read" means there was and error when the camera tried to access the memory card. To fix this you should make sure you are using the right kind of memory card, which for this kind of camera is a SD card, and it does not support SDHc cards. Since this camera uses SD cards I would make sure the slider on the side of the card is not set to the locked position. If this doesn't help I would make sure the memory card connecters are clean, and if they're not you can use a rubber eraser to clean them up. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 11, 2008 | Nikon Coolpix 4600 Digital Camera
DIGITAL READ OUT SCREEN
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We also have the complete service manual for this model at our site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 31, 2008 | Microwave Ovens
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
