Question about Refrigerators
REFRIGERATOR NOT COOLING ENOUGH HAVE TEMPERTOR CONTROL ON COLDEST NUMBER. PLEASE ADVICE. THANKS.GILBERTO ZUNIGA
the dr
  • 447 Answers
SOURCE: My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Posted on Oct 03, 2007
docjohn174
  • 943 Answers
SOURCE: My refrigerator is acting weird!
Hi. thanks for the question. I would check the fan motor, in the freezer. cut power to the fridge. remove back panel. replace the fan motor. clean all ice at the bottom of freezer. clean the drain ,from freezer to the back by the compressor thanks the appliance doc. please rate my answer.
Posted on Oct 07, 2008
heatman101
  • 43501 Answers
SOURCE: Fridge not cooling, freezer not freezing even on coldest settings
From what you are describing, you have a refrigerant leak. The freon has leaked from the system, The compressor will still run and evrything looks fine. To double check you will have to have someone hookup gauges to the system and verify that the charge is lost.
It may be possible to find and repair the leak. This is not always possible as some of the system is virtually inaccessible in many refrigerators.
Make sure if you do have someone repair the system that they evacuate the system very well and do a good vacum test before recharging the system.
This should help you to solve your problem.
Thanks for using Fixya!!
Heatman101
Posted on Nov 24, 2009
  • 401 Answers
SOURCE: I have a Whirlpool ED22DQXEW01 regrigerator. If I
This sounds like a faulty cold control.
Posted on Jan 09, 2010
SOURCE: gshs5kgx refrigerator not cold enough, controls
Did you solve this problem? We're having the same problem on our GE same model, but no turbo cool option.
Posted on Feb 24, 2010
What is the coldest setting for a kenmore refridgerator
If your refrigerator section is not cold enough at the normal setting you may have a problem.
If you can't find enough information at the link below resubmit your question and include the model number. It should be inside the refrigerator section. It's usually on the upper right wall.
refrigerator not cooling but freezer is fine YouTube
kenmore refrigerator not cooling YouTube
Sep 07, 2014 | Refrigerators
Samsung Iceworld 380 not getting cold enough
Check the compressor, condenser coils and fan on the back of the unit for lint and dirt buildup. It needs to be clean to cool properly.
Nov 05, 2012 | Refrigerators
I have a Maytag refrigerator similar to the current model (GS2625GEKS), I purchased mine in 2003. Serial number unknown. All of a sudden my freezer is way too cold and my refrigerator is not cold enough....
If the number is similar we will have to go with possibilities. Sound like the auto damper has frozen itself shut between the fresh food and freezer compartments. Some are controlled electrically some manually and others are controlled with a thermostat probe. Your thermostat for one side could be defective and not allowing the damper to open. Your refrigerator must have the correct model number to proceed. What I need you to do is look for the vent through the rear of the refrigerator compartment and sometimes leads directly from the same wall as freezer. Many Maytag brands fall under same series and model similarities. The serial number is not as important to the service Tech as the model number. Look around the door frame near floor and kick plate.I can help but I will need the correct model number, Thanks, Sea Breeze
Feb 13, 2010 | Refrigerators
Hi .The freezer is cooling but refrigerator side is not getting cold enough.It will only get done to 50 F with the control set at coldest. The freezer is 8 F with control set at 2:00 oclock. There is no...
Read the Below Guide Written by Me:-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 30, 2010 | Frigidaire FSC23F7D Side by Side...
Refrigerator is not cooling enough even it is already set to the coldest. in a rare situation, the compressor and the fan motor will turn on for a few minutes and that's it... it won't cool the...
Need that model number. Sound like a defrost problem and the defrost timer or the defrost heater and defrost thermostat is defective. I need you model number could you send that so I can help you better? Thanks, Sea Breeze
Comments. If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 29, 2009 | Refrigerators
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
