Question about ASUS CROSSHAIR Motherboard
Computer won't boot up
I just put together my first computer. It took me 2 days of cursing and headscratching to put it together. So the problem is when I turn it on, nothing happens except the motherboard lcd just says cpu init. The processor fan doesn't even turn on. I tried the stock processor fan and a thermaltake v1. Neither of them turn on. I'm pretty sure I had them plugged into the right fan power connector. The Connector is the only 4 pin connector in the area that the diagram says it's in. The monitor (Samsung SyncMaster) just says check signal cable. My step uncle triple checked that everything was connected properly on the intial install. He took off when I was putting in the sound and graphic cards. It's a Asus Crosshair motherboard with a dinky sempron processor that I had to get the thing running so I could update the bios and put in a quadcore. I bought the motherboard last year before amds' quads came out incase you were wondering why I bought that board in the first place. The PS is a thermaltake 700watt. Four gigs of Corsair Dominator 1066. Soundblaster X-FI Elite Pro. Nvida 9800 GTX2. Any help would be greatly appreciated.
    Scholar:
  • 104 Answers
Make sure that your power switch is connected to the correct pins on the motherboard. The LED you see lit may be the stand-by power indicator saying it has power and is waiting for the signal from the power switch.
Posted on May 06, 2008
I took my desktop apart and put it back together and now it won turn on
Open it back up and check to make sure you didn't accidentally pull one of the cables out.
Jun 30, 2012 | Dell Computers & Internet
I can't run "Curse: The Eye Of Isis" in Windows Vista - any hope ???
I have a "virtual" copy of Windows running on my computer at home that use for running older games and applications. There are several free programs out there... Microsoft has one: Virtual PC and there is a Open Source version hosted by Oracle: www.virtualbox.org With a dual-core or higher, 2GB or greater RAM, you can run a virtual desktop with ease... All you'll need is a old copy of Windows to install (e.g. Windows XP, Windows 2000, Windows 98)
Nov 15, 2011 | DreamCatcher Interactive Curse: The Eye Of...
I just took apart my computer and put everything back together again but i get no display when i turn the computer on.
A common problem when putting a computer together is assembling the hardware in an incorrect order. 1. Install your CPU and fan 2. Install your RAM 3. Install the graphics unit 4. The order of the other components does not matter. 5. Connect power to all components and boot up.
May 03, 2011 | Computers & Internet
I loaded witchis curse princess lsabella now i can not remove from my computer ever time i load my computer it loads game again and has to do a repair set up
Try press the F8 key several times as the computer boots up, then select boot up in Safe Mode.
When Windows starts up in Safe Mode click on Start - Control Panel - Add Remove program and select the Isabella program to Uninstall.
When the program has been removed then Shutdown the computer and boot up normally to see if the computer starts up normally.
If you still have a problem, please leave me a comment and explain what happened together with any error messages.
Jan 31, 2011 | Computers & Internet
I-BOOK A1005 Monitor dead....
this should be because the parts inside doesnt fit properly
Jul 03, 2009 | Apple iBook Mac Notebook
Hard Drive won't boot Windows
yes.. because the booting information and booting files are sored only in active primary partition of a hard drive. i.e primary drive. if you remove the primary it wont recognize the OS with out booting information. you should need to reinstall OS.
Dec 22, 2008 | HP Pavilion dv6000z Notebook
Ram Memory
I did this 2 days ago on my gf's aspire 5315-2153 (walmart special $348). the underside panel has four tiny screws which must be removed and then the fun begins. The plastic panel is large and doesn't want to be removed. After 20 minutes of cursing, i was able to get it out with two hands and a small screwdriver. The plastic panel has about 7-8 tabs which also hold it in place. The original two memory modules must be removed and the two new ones installed in their place. i bought crucial memory from newegg.com (CT2KIT12864AC667) for $17 delivered (took a week to get) which was much cheaper than buying it direct from crucial.com Save the old memory modules just in case you have a problem with the new ones. After putting them in, I restarted the computer and it booted up fine. No BIOS changes or any of that were necessary. So for $17 and about 30 minutes, this lappy is now running strong with 2gb instead of 1gb. Initial impression is that it boots up faster and shuts down faster but that is about it in terms of improvement!!!
Aug 24, 2008 | Acer Aspire 5315 Notebook
Boot problem
Was the operating system installed on another computer? Or a computer with different hardware? If so the drivers for the hardware are not configured properly on the HD or in the BIOS. If this is the case you should format the HD and re-install the OS.
Aug 15, 2006 | Jetway N2VIEW Motherboard
ASUS CROSSHAIR Motherboard Logo
241 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
