Question about Delta Saws
Need instruction book for K9513 MOdel 40-560 Type/Tipo 2 Delta jig saw
efs_perpends
  • 1996 Answers
SOURCE: BLADE CHANGING
What's the model number of that saw?
If it's one of the old ones, a 1581 VS or some such, you need a long thin flat-head screw driver that fits through the hole in the top of the handle and reaches down far enough to unscrew (loosen it) the set screw that holds the blade locked in place. Then you twist the blade 90 degrees (perpendicular to the direction of cut), and pull it out. Reverse process for installation, making sure before you tighten the blade it rides in the groove on the guide bearing below.
If that doesn't seem like it's the correct sequence for your saw I apologize.
The Bosch website won't accept any 10 digit tool product numbers due to some glitch in the system, and they made so many variations on that saw it'd make your head spin.
That's the other way some of them loosen up, actually, is by pulliing up the plastic head at the top of the handle and unscrewing it a few turns to loosen the blade.,, Vice versa for install..
Hope this helps a bit!
Posted on Mar 28, 2009
SOURCE: Instruction manual for Bosch Jig Saw 1587AVS
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
This is the Owner's Manual for the Bosch 1587AVS Jigsaw.
Posted on Jun 24, 2009
  • 142 Answers
SOURCE: I have an old and very heavy cast iron Delta jig
generally any machine oil will do, The oil needs to be lighter than motor oil, but thicker than pneumatic tool oil. I would bet that compressor oil would work, it is relatively inexpensive and I believe thin enough for that application
Posted on Jul 08, 2009
nclark557
  • 15 Answers
SOURCE: looking for parts for a Rockwell 648 jig saw Type
go to a hardwear
Posted on Jul 28, 2009
brewerstool
  • 141 Answers
SOURCE: jig saw model 7580 type 4, replacement for blade clamp
There is no model 7580 Jigsaw. The only model close to that I can see would be the 7588 Type 4. Unfortunately that part is unavailable for this model. You may want to contact your local Dewalt service center and see if there is a substitute for that part.
Posted on Sep 12, 2009
I need a manual for a Delta 40-500 15" hobby scroll saw
The closest I could find is the Delta 40-530 16".
http://documents.dewalt.com/documents/English/Instruction%20Manual/Delta/En%20900621.pdf
Here is a parts diagram for Delta 40-500 type 1
Delta 40 500 Type 1 15 34 Scroll Saw Parts
Here is a parts diagram for Delta 40-500 type 2
Delta 40 500 Type 2 15 34 Scroll Saw Parts
Oct 09, 2016 | Saws
Manual for delta 40560 scroll saw
First you might try this link Delta 40 560 Type II Instruction Manual for a free download. I think there may be others.
Though not an instruction manual, this website Delta 40 560 Type 2 16 34 Scroll Saw Parts gives exploded diagrams of the saw.
Finally have a look at the Delta website http://www.deltamachinery.com/ and see if you can find a download there or ask for one.
19.January.2016
Jan 19, 2016 | Delta Two Speed 16" Bench Top Scroll Saw,...
Need instruction Manuel for delta tenoning jig
Go to the Dewalt Service website at http://servicenet.dewalt.com/ and put your model number in the Find Parts box. Hit search and you'll be presented with a page where you can view or download the parts breakdown or the instruction manual.
Jul 31, 2012 | Delta 34-184 Universal Tenoning Jig
DELTA YENONING JIG 34-184 WHY DOESNT FACE COME OVER TO BLADE? I GOT 5 1/2 INCHES FROM BLADE TO SIBE OF MITER SLOT,THAT A NORMAL SLOT OR MINE FARTHER AWAY
That's a normal mitre slot distance.
You may need to re-align the jig depending on whether your saw is a left or right tilting saw.
You can download instructions for your jig that tell you how to do so here.
Otherwise, I can only say that I have had the same question, and can only think that the jig was designed with the idea that you would screw your own backing plate against the face of the jig, to hold pieces in place or back them up as they passed over the blade, and for that reason the face is so far from the blade. (But I think I was using the jig on a powermatic saw at the time.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 17, 2011 | Delta 34 - 183 Tenoning Jig
Need owners manual for Delta scroll saw model 40-530
The Instruction Manual for the Delta 40-530 Scroll Saw can be found at the following site:
http://servicenet.deltaportercable.com/Products/Detail?isId=true&productNumber=40-530&selectedType=9859
Note there are two types. The model number on your saw will be followed by either -1 or -2. The link above is for the -1 model. The following link is for the -2 model:
http://servicenet.deltaportercable.com/Products/Detail?isId=true&productNumber=40-530&selectedType=9864
Sorry someone has not responded sooner.
Oct 13, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
How do I change the blade on a Black & Decker JS500 jig saw?
Go to Dewaltservicenet.com and type in your model number and you can download the instruction manual for this tool with detailed instructions on how to change the blade. It is 8 pages long.
Oct 03, 2009 | Black & Decker Scroll Jig Saw Blade
I have an old and very heavy cast iron Delta jig saw. I need to replace the oil in the lower end sump. What type oil is needed?
Jul 08, 2009 | Saws
Saws Logo
59 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
