Question about Linksys Wireless-G Broadband Router
Wireless has vanished
Hey, I can not see my wireless router. I believed it has vanished as well. Any luck?
  • orangeboy May 06, 2008
    EXCELLENT!!!!!! THANKS A MILLION!!!
  • 156 Answers
Have you reset the router?
Check the routers programming and tell the SSID to broadcast
Login to the router by typing 192.168.1.1 in an open IE window the default user name and pass are both admin
Change the name of your SSID from linksys to something familiar like your last name.
Might be better to factory default the router and start the programming over double check your WEP keys if you have any encryption codes set on both router and any PC's.
If these steps don't resolve the issue just let me know here and we will determine the cause.
Posted on May 06, 2008
Cannot connect my router to get wireless for my ipad2. I have a d link 624. How do I reset it?
Hey,
I believe there should be a tiny reset button in the back, which you'll have to press for 15 seconds using a paper clip. This will reset the ENTIRE configuration of the network, so it will reset with the DEFAULT username and password, which you might have to call D-Link if you don't have the information.
There's more information on that over here: http://www22.verizon.com/residentialhelp/fiosinternet/networking/troubleshooting/questionsone/86195.htm
Just a note: it might not necessarily be the router's fault because I've heard that many people had problems with their iPad's wireless network after they updated to the newest firmware, which is 4.3.3. So, if you don't want to do mess around with your router, you can either wait for a new software update, or downgrade it, if you have the necessary files.
Good luck, -virjog
May 17, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Security lock has vanished, how do I make my system secure again?
you will need to browse to the following location 192.168.0.1 on internet explorer or another browser.
the default login/pass is
  • Username = admin
  • Password = password
  • or pass = 1234
  1. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  2. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Mar 27, 2011 | NetGear WGR614 Wireless Router
Router password
>If you're trying to put password for the Router, then type "http://192.168.0.1" into the address bar, then hit "Enter."
>Use "Admin" as the username and leave the password blank when the login screen appears.
>Please click on Administrator settings and change the User Name and Password.
If you're trying to put a password/secure the Wireless network, then follow the steps:
>In the Router setup page, click on Wireless Settings.
>Under Wireless Security Mode, select Security Mode: WEP/WPA/WPA2.
>Enter the Security Key manually or enter the Phrase to generate the Security key automatically (only in WPA/WPA2) and save the settings.
>Please note the Security Key to connect to the Wireless Networ.
>The Wireless is secured now.
Good Luck!!!!
Jul 02, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Internet light vanished on Wireless N and won't come back
1. log into the router and check the status page of the router.
2. check with the ISP to see if the connection to your premise is good.
3. logging into the router is: a.bring up browser page and type in 192.168.0.1 or the ,manufacturers ip for the router.
type this into the URL.
Apr 28, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
After shutdown or restart, wont recignize wireless routers
A couple things:
1) Get the latest software from the web and use that.
2)Try to find a way in the software to make a profile to save the settings, or make your home location default.
Weak, but worth a try. Good luck. Jidza
Jan 23, 2009 | Dell (tmbun2) Wireless Router
Belkin wireless router
If you type the ip adress in your internet browser you would be sent to the sentings for your router. There sould be a secsion for wirless setings thats where you would secure it with a WEP password.
I hope this helps
Jan 02, 2009 | Belkin (F5D7230-4) Router (587009)
Problem with wireless router
What is the model number fo your router? If you know how to access your router setup page using a computer wired to the router you can change all the wireless settings there like the SSID or wireless network name and disable again the wireless security.. or if you want someone to walk you through with that you can call your router manufacturer so they can alos help with your concern...
Good luck......
Aug 11, 2008 | NetGear RangeMax WPN824 Wireless Router...
My linksys network has vanished
I hope the solution I provided you in chat helped.
May 05, 2008 | Linksys Wireless-G Broadband Router
My laptop won't work wireless
Use windows network setup wizard to help in setting up your wireless. The wizard can search for your wireless. Some people believe you gan get away without using Linksys's software & I agree to a point. However Linksys believes to maintain a good connection you should install the software for the wireless router. You can download it from the link below. Check out the link "Learning Center". You might find it helpful. http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740137401B343
I suggest to all running a wireless connection to set up security with a password to keep freeloaders from tapping into your bandwith for free.
Luck!
Please vote...
Jan 23, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
