Question about Miller Electric Mfg Co 903394 Deltaweld 452 MIG Welder, 3- Phase, 15 - 38 V
Deltaweld 452 welds fine (sub arc) then the voltage goes to 3 or 4 volts wire stick and breaks the tip.
5 Suggested Answers
luxur4
  • 92 Answers
SOURCE: the ground clamp has voltage
WARNING ! You have an earth leak on the unit, before you do any more work with this set, have it checked by a qualified electrician, it can be HIGHLY dangerous to continue. the leakage can be on the mains side and can cause you serious injuries. dont atempt to repair or examine yourself.
Posted on Jan 23, 2009
  • 5 Answers
SOURCE: Need Technical manual fro calibration purposes.
what problem are you haveing with it
Posted on Sep 15, 2009
  • 12 Answers
SOURCE: The arc sputters when welding.
I've had slot of experience with these migs. Usually when the arc sputters, it could mean 2 things, either the roller feed tension is too light, or the liner in the pistol lead is worn. It's the flex tube the wire travels through. If it's worn the wire will hang up or snag, causing the arc to sputter. If you tighten the roller tension, and the wire back-lashes, that's a sign to change the lead. First try adjusting the speed of the wire accordingly to the heat.
Posted on Jul 30, 2011
SOURCE: Miller deltaweld 452 power source is reading EEE
Replace the digital meter board, its function is to also control the voltage to the unit and read the amps.
Posted on Dec 12, 2011
Cooling fan
check voltage going to the fan motor - no volts check power relay or source. also check for volts on the motor name plate and polarity if it has any.
no volts means something is not feeding. volts present could mean bad motor.
Feb 28, 2012 | Miller Electric Mfg Co 903394 Deltaweld...
Miller deltaweld 452 power source is reading EEE code in the voltage slot ???
Jun 15, 2011 | Miller Electric Mfg Co 903394 Deltaweld...
Stringy welds
Turn the heat higher and the wire speed lower and you will get better welds...
try to turn the heat up first....
heatman101
Mar 04, 2011 | Miller Electric Mfg Co 903394 Deltaweld...
I own a Miller "Sidkick" MIG welder. It has been
Hi:
If everything works but there is no arc; you should check your ground clamp, make sure it is not loose or dirty including terminals and replace your gun's contact tip.
Believe it or not this is a simple one.
If this was useful to you please vote. Thanks
Feb 25, 2011 | Miller Electric Mfg Co 903394 Deltaweld...
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Miller Electric Mfg Co 903394 Deltaweld 452 MIG Welder, 3- Phase, 15 - 38 V Logo
111 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
