Question about Refrigerators
Running but not cooling. - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Why is My 04 PT Criuser running hot and there is coolant in the radiator ?
check your cooling fans make sure they are working, to do this start your engine and turn on the ac the cooling fans should be running, if it does the next thing to check is the temp sensors, to do this turn off the ac, while the engine is running keep an eye on your temp gauge if the dial is going up above normal or at the point where you say the engine is running hot check if the cooling fans are running,
1) if not running, cooling fan sensor is not working, replace
2)if running, thermostat is shut, the thermostat regulates the flow of coolant in the engine it is fully open at normal operating temp and close if coolant is cold, replace
how to replace thermostat go to https://www.youtube.com/watch?v=dG5MhY8Bieo
Aug 16, 2014 | Cars & Trucks
My fridigaire FFUS2613LS is not cooling
Good Afternoon Timothy,
I understand your Frigidaire refrigerator, model# FFUS2613LS, is not cooling. I also see that you hear the motor running, can't feel the fan running, and it is not cooling. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the fan is not running and your refrigerator is not cooling. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire FFUS2613L Side by Side...
My 1994 Toyota Previa LE overheats when I put on AC. It overheats while on idle.
cooling fan not running.check for faulty cooling fan relay or fuse.cooling fan fan should be running when you turn on AC.hotwire cooling fan make sure cooling fan motor okay.
Jul 10, 2013 | Cars & Trucks
I just bought a 1995 jetta and it's running at 260 degrees. Is this too high, and if it is then what would be causing this?
CHECK TO SEE IF BOTH COOLING FANS RUNNING ARE RUNNING WHEN ENGINE RUNNING START OVERHEATING IF COOLING FANS NOT WORKING CHECK COOLING FANS LARGE FUSES IN THE ENGINE COMPARTMENT OR YOU COULD FAULTY COOLING FANS THERMO SWITCH BOTTOM LEFT SIDE OR RADIATOR.IF COOLING FANS IS WORKING WHILE ENGINE RUNNING.RADIATOR CORES AND HEATER CORE COULD BE CLOGGED.COOLANT SYSTEM NEED FLUSHING. THE THERMOSTAT PARTIALLY CLOSED CAUSE ENGINE OVER HEAT.CHECK WATERPUMP WEEP HOLE IF LEAKING WATER PUMP NEED REPLACING.
Jul 21, 2011 | Volkswagen Jetta Cars & Trucks
Icemaker not completly filling. Freezer not defrosting, coil icing. New this AM fridge section not cool running 50 degrees. Fan in freezer running. Defrost unit replaced at some time in past.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | GE Refrigerators
Refrigerator is not cooling, but the freezer is....
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
q
May 08, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
Lower unit does not cool
check for conditioned space fan not running. Does top cool and not the lower or are both not cooling properly. If fan is running, it could either be that the thermostat is not set low enough, evap is frozen up, the unit is low on freon, the compressor is not running. Start checking as much as you can and let me know.
Mar 22, 2009 | Carrier Beverage Air® DP46 Commercial...
Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Jan 01, 2008 | GE Profile JTP18 Electric Single Oven
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
