Question about Canon imageCLASS® MF6550 Laser Printer
Canon imageclass mf6550
I changed the new toner but its print out empty page , I thought there are problem in the scanner I tried to send fax to other machine and Its came out perfect , so there is the problem in printing system , Please any idea what is be the problem , since this model had no head there should not be a dirty head neither !! Please help some idea so I could check its out !
Thank you Huot Fujita
  • 2,098 Answers
If the paper feeds through but nothing is on it, it indicates that the toner is not being properly fed. Go to this link, type "printout is blank" in the Search window and click the search button. Next, click on the "Printout is blank" line, and review the document. Especially check that you have removed the seals from the toner cartridge (see steps 7 and 9 on the second part).
Posted on May 07, 2008
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
I have faxs stored in the memory but do not know how to print them?
It should print by itself unless you have an error message (Low Toner, or Incorrect Paper Format or no more paper) and your Cont. Printing setting is set to OFF. To set it to ON, go in your Fax Settings, then Printer Settings, then Cont. Printing. This works on my MF4150, hopefully this will also work on its older brother MF6550... Just check your user manual (if you lost it, check canon's website).
Nov 20, 2009 | Canon imageCLASS® MF6550 All-In-One Laser...
Cannon ImageClass mf6590 toner cartridge issue
I have the same question. If you get an answer please send me a reply. aste2426@aol.com Thanks!
Sep 22, 2009 | Canon ImageClass MF5770 Laser Copier...
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Multiple fax copies only 1 or 2 get through
First check to see if all 5 are bing sent. Sometimes paper sticks to each other and you may only see 1 or 2. Also your telphone line has a lot to do with it. If you are using a digital telephone line with your internet line such as a vontage telephone, the signal is takene from your internet line for your telephone and sometimes such as when you are on the internet and trying to fax, you do not have enough signal strength. sometimes sutting off the internet works. Also what does the report say from your copier/fax are 5 pages being sent. In the set up this Canon you can get a report after you send a fax....
Jul 09, 2008 | Canon imageCLASS MF6550 Monochrome Laser...
Canon mf 6550
The laser Apeture is sticking.
What i did to mine it Sorta hit it on the paper side and caused the shutter to start working
if you take the toner and use a screwdriver to push down the shutter, it will start working again.
the shutter is sticking.
May 06, 2008 | Canon imageCLASS® MF6550 Laser Printer
How to locate the printer head for model mf5500
The Canon MF5500 series are laser printers. There is no print head. If your pages are coming out blank, check that you have sufficient toner. If you have toner, then the machine may require service.
Canon MF6550
Try to press te System Monitor Button and scroll using the > to Print Status. If there is a print job in there press ok the < to cancel the print job. You may want to check the other status windows in case it is a Fax or Copy job instead of a print job.
Apr 18, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Canon imageCLASS® MF6550 Laser Printer Logo
155 people viewed this question
old marine
old marine
