Question about Directed 434MHZ Remote Control
What is the remote code for the LG LHB535 Home theater sys
Tip
LG LH-D6235 Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | Audio Players & Recorders
Tip
Follow these steps:
I hope that helps.
on Jul 14, 2010 | LG LH-D6230 System
I have a LG HT 904 with an integeral ipod dock. Our son has damaged thedock by pulling on the ipod, it no longer works. Can this be fixed?? Thanks James
depends what is actually broken. How handy are you ? take each unit apart to locate the problem, make sure you check both so your not doing this again. If the fiber board at the connections is broken it can be glued with an epoxy, make sure you dont get it on any circuit paths. if the circuit paths have been broken, dab a bit of solder on them to reconnect. I cant stress enough, take your time, their delicate to begin with.good luck to ya
Mar 04, 2011 | LG LHB535 Theater System
I have periodic buzzing from the right rear speaker
I had that followed by no audio. I had the system for a year but just hooked it up last month, used it a handful of times and it worked great...anyway, a reset didn't help so LG said to mail it in to Huntsville, Alabama along with $69.
Jan 14, 2011 | LG LHB535 Theater System
My lg 535 won't update. I'm connected wireless to the Internet,and I'm hearing whistling coming through the center and right front speaker,and the movie avatar is skipping sections of the movie and this is...
Had same issue. LG Online has instructions for downloading update to flash drive and loading from there. Since then it has updated without problems. Not sure if the skip has gone away or not though.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6348
Jan 03, 2011 | LG LHB535 Theater System
My Comcast remote will control my LG LHB535 receiver/blue-ray player in all respects but the volume. I used code 20591.
You need to change the volume lock for the remote to go to your AV receiver, not the TV. By default all Volume control will go to the TV, but you can change volume lock to go to AV receiver instead. I switched to DirectTv and had to do the same thing, so I may not have the right term used on comcast, but essentially the same thing.
Dec 29, 2010 | LG LHB535 Theater System
I can not get any audio from the hometheatre when turning on TV only the audio is coming out is from the regular TV speakers. However when playing a DVD or Ipod the audio is coming out from hometheatre...
hi,
connect your tvs or cable set-top box's digital audio out to the digital audio input of ur home theater. the select the corresponding input in the home theator.
or connect set -top box's to HDMI input 1 of ur home theater, and connect its HDMI out to ur tv. assign the corresponding inputs for the hdmi 1 in ur home theater.
ok
Dec 21, 2010 | LG LHB535 Theater System
LG LHB953 Theatre system volume control with comcast dvr 3
Try the help menu in the comcast remote. I believe you have to program it again for the LG to work the sound.
Jan 01, 2010 | Televison & Video
Need Remote Code for LG LFD790 Home Theater
I NEED REMOTE CODE FOR LG LFD 790 FROM REMOTE GE
Dec 30, 2008 | LG LFD790 System
Televison & Video Logo
232 people viewed this question
Top Directed Televison & Video Experts
Christopher Stearns
Are you a Directed Televison and Video Expert? Answer questions, earn points and help others
