Question about Maytag Neptune MCG8000AW Gas Dryer
Tumbler will not spin - Maytag Neptune MCG8000AW Gas Dryer
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
How do I fix the remote on the RC Thunder Tumbler RC Car to prevent the tire from spinning as soon as the remote control is turned on?
Use the throttle trim control to try and adjust this unwanted throttle application out. Refer to the user manual on how to trim the remote functions
Oct 17, 2016 | RC Thunder Tumbler Rc Car
I have an LG-WD-1433RD . My dryer wont spin dry what would be the problem
Most basically it can be 2 things assuming it powers on and the touch controls act normally.
1. The belt that drives the tumbler around is broken and therefore it isn't spinning.
2. The motor that spins the tumbler is blown out and needs to be replaced. Again, no spinning.
In either case they are an easy fix and most any good dryer repair tech can fix it quickly. I've done this type of repair myself, but you have to be handy AND careful because if the exposed sheet metal edges. I always wore gloves and a long sleeve shirt.
Good luck. Having your dryer out stinks!
Hope this helps, please don't forget to rate or ask a follow-up question.
Jul 15, 2014 | Washing Machines
The tumbler is making alot of noise and the dryer is getting extremely hot.
check that the drumb (tumbler) is turning, sounds like ur belt is broken and not turning but the pulley wheel is spinning and making a racket...
Apr 15, 2011 | Kenmore Dryers
I have a GE Front Loader. Model# GHDVH670H1GG. The tumbler works until water is required to be drained. At that time, the tumbler is trying to tumble for rinse, but, the water is not being drained and not...
On my machine the pump filter was clogged preventing the water from draining out of the machine properly. This would leave the clothes soaked in water as the machine tried to spin, the extra weight caused the drum to rub against the door seal while spinning, causing the burnt rubber smoke! I removed the 3 screws on the lower fron panel of the machine and opened the drain ( make sure you have a pan or bucket to catch the water! ) cleaned the fliter and put everything back. Works like new again. Good luck.
Sep 22, 2010 | GE WSXH208A Front Load Washer
Machine is stuck on fast spin.
First Start your machine with a low spin and slowly slowly increase the speed until it becomes fast I hope it helped : )
Aug 25, 2010 | GE WBSR3140DW Top Load Washer
Dark stains occuring in a pattern of dots on garments (pattern
operate one quick cycle with not load with hot water and detergent to clean the drum
Mar 18, 2010 | Frigidaire 14 Cycle Tumble Action Washer
My tumbler won't turn. Tried unloading some rocks but still having a problem.
I had the same problem, The problem is that the tumbler lid is to smooth and there is no grip from the spinning wheel. I solved this problem by taking a kitchen steak knife and roughing up the edge of the tumbler where it rides on the spinning wheel. Works great now. Best of luck
Mar 06, 2010 | Rotary Thumlers Tumbler Polisher...
My neptume will not wash clothers. the tumbler
if it's noisy in the spin i'd be in the market for a new washer,there's a spinner support assy. that goes in the rear of the drum,for the price it will cost for the part and labor you'd be close to a new washer
Feb 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Tumbler wont spin during spin cycle
Have the motor checked. It may stuck up and needs rewind.
Jul 22, 2009 | Washing Machines
Dryer runs belt not broken and tumbler doesn't spin
the belt may not be broken but it might be stretched past its limits check and see if the electric motor is spinning when the belt is off but my personal suggestion is take a digital picture of the belt on the pulley and tensioner so you can reference it when putting it back together
Apr 13, 2009 | Dryers
Maytag Neptune MCG8000AW Gas Dryer Logo
57 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
