Question about Thetford Norcold DE0051 Refrigerator
I have a norcold referidgator model no. n811rt how do you reset it ?
I have a Norcold Model N811RT. Freezer and refrigerator stopped cooling and freezing. Days later they're working. I live fulltime in the RV, is there something I should check?
I would check the evaporator coil and see if it is occluded with dust and dirt. Freezing up is usually the result of inadequate air flow over that coil. It looks kind of like a car radiator. You can buy evaporator, and condenser coil cleaner on Amazon. I do this every year to both of mine, it makes a huge difference in output.
Jan 13, 2017 | Cars & Trucks
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
We have a Norcold model N811FLT, it is connected to power, but is continuously running on gas. We've tried resetting it with no change. Could it be the power board or the control board?
you can reset the control board . to do this you must ground the # 15 terminal with a jumper wire to ground. this is usually the terminal next to the white & violet wire. check diagram.
Jul 07, 2014 | Thetford Norcold RV Cooler/Freezer
Norcold fridge model N811RT 5 blinks on light code what is the problem
This would be a great answer if you also provided instructions on how to 'remove the unit from it's resting spot'.
Thanks!
Dec 04, 2011 | Refrigerators
Want to reset board on N611 norcold ref
The Norcold board reset is done by jumping a pin terminal to ground. There are several steps involved but it's all pretty straight forward. Here is an article on the steps of doing this: Norcold Refrigerator in Lockout Mode do you need to reset your power board
Jun 09, 2011 | Thetford Refrigerators
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
How do you reset circuit board on norcold refrigerator
No way to do that other than to unplug refrigerator for at least ten minutes and then plug back in. Don't use surge protector, power strip, or extension cord.
Sep 21, 2009 | Thetford Norcold DE0051 Refrigerator
Norcold rv cooler code needs reset reading no co
u need to take into dealership or have a tech reset the board if not done right u can blow your board out
Sep 19, 2009 | Thetford Norcold RV Cooler/Freezer
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
Fault code on norcold refer model 640.3 reads "no" "co",how do I reset
u must take into a dealer or have a mobile tech to reset the board
Jul 29, 2009 | Thetford Norcold RV Cooler/Freezer
Thetford Norcold DE0051 Refrigerator Logo
1,037 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
