Question about Dell 1200MP DLP Projector
Dell 1200mp Getting the message "Please change VGA cable toi monitor in" The projector is two years old with only 8 hours use.
  • 563 Answers
Hi jezzwhizz
You'll see that at the back of your Projector there is 2 VGA ports 1 in (normally blue) and 1 out ( normally grey ).
You are most probably using the grey one , switch it to blue.
Posted on May 07, 2008
No image on projector screen from laptop VGA connection
On most laptops you have to select Function F8 to direct output to the projector or the projector and the laptop display.
May 07, 2012 | Dell Inspiron Mini 10 Notebook
Changed bulb on the 1200mp and when i turned it back on the bulb came on showed the dell logo and then the temp light came on after this the projector went into stand-by mode. when i restart it does the...
Just went through this issue with a 1200MP. The cause of the failure was a failing optical speed sensor on the color wheel assembly. It overheats and produces an invalid signal shortly after startup, causing the projector to shut down. The good news is that this is a $2 part. The bad news is that I wouldn't really call this a "DIY" repair unless you have the ability to unsolder and replace tiny surface-mount electronic components. You will also have to do extensive disassembly just to get at the part, which is buried inside the optical system. I am a professional electronics tech, and removing/replacing the part took me about 2 hours on a fully-equipped workbench. Troubleshooting the unit to FIND the failed part (without any service manual or schematic) took another couple hours, FWIW.
If you want to give it a try, the part you need is a GP2S27 "photointerrupter" manufactured by Sharp. These were discontinued a year or so ago, but some distributors still have stock (get them while you can). I got mine from DigiKey. This is a tiny little part about the size of a match head, with 4 terminals that need to be soldered onto a small circuit board, after removing the old part. You will need a steady hand, a fine-pointed soldering iron, and a magnifier with plenty of light.
Aug 22, 2011 | Dell 1200MP DLP Projector
I have a Dell 2300MP projector which works perfectly in cloned monitor mode with a 3-year-old desktop computer running Windows XP with an ATI card. I have very recently bought a new desktop running under...
Hello
This problem was also faced by me some time ago, i just change the data cable (vga cable) and then it will recognized by system,
i suggest to change the vga cable and try to find the DVI cable if possible to connect the projector to system end.
Hope this helps.
Jan 25, 2011 | Dell 2300MP Multimedia Projector
Trying to hook up projector to a mac laptop to run a slide show and not sure if connected correctly any sugestions?
Mac will have an adapter on the display output in which you will connect this to a VGA cable and to your projector.
Jun 12, 2010 | Dell 1200MP DLP Projector
Dell 1200MP works with PC but not the DVD player,
Hi.
If you have a replacement cable test the DVD using a different cable, you never know.
Try the following:
  • Unplug both projector and DVD from power.
  • Keep units connected together by video cable.
  • Connect back and restart the DVD first.
  • Restart the projector only once that DVD is ON.
If it still does not work , then there may be a fault.
Nov 09, 2009 | Dell 1200MP DLP Projector
Our DLP 1200mp projects a yellow back ground no matter what the colour of the ppt. slide.
try to replace your vga cable. if this problem occur again get help to your technician, maybe this problem is in the glasses inside of your projector.
Oct 28, 2009 | Dell 2400MP DLP Projector
My remote won't work on my Dell 1200 projector
remote wont click to next page on Powerpoint presentation
Mar 05, 2009 | Dell 1200MP DLP Projector
1200MP DELL Projector flickering problem
You should not try it for yourself, Call a Professional instead.
Jun 26, 2008 | Dell 1200MP DLP Projector
DELL 1200MP projector problem
I don't know that particular model, but usually these are hung u pside down and the projector can flip the image. That should take care of it. Also, depending upon the angle to the screen, you may need to adjust the "keystone" as well. That will allow the final picture to be square as if the projector was at the correct angle.
Dan
Apr 17, 2008 | Dell 1200MP DLP Projector
Dell 1200MP DLP Projector Logo
103 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
